Results 1 to 8 of 8
Thread: Vp s PAC troubles
    90 vn wagz and 90 vn sedan
    Feb 2010
    Default Vp s PAC troubles
    Posting about this for a friend, his vp starts moves 10 meters and doesn't start. Why could the problem be? Any help would be great, cheers.
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    any other details? noises? see what error codes come up, might get some better answers...
    dont sweat the petty... pet the sweaty...
    Feb 2010
    WazzaVN's Avatar
    WazzaVN is offline Wazza VN
    VP Calais
    May 2008
    At the end of last year my VP was stalling all the time and i found out i needed a new computer. but it sounds like it could be a huge number of things, like a crank angle sensor or something. see if the engine light comes on before it stalls then you can get someone to plug in a computer and give you a diagnosis. mine was running for roughly 10 mins before it was stalling too.
    Feb 2010
    Where abouts would I find the computer? An what exactly is the crank angle sensor?
    Aug 2008
    crank angle sensor is right behind the harmonic balancer (ac compressor side), computer is behind the kick panel passenger side just below the dash (interior side of the A pillar). crank angle sensor senses the angle of the crank shaft using the harmonic balancer...
    WazzaVN's Avatar
    VP Calais
    May 2008
    the best way to find out what your issue is, is to check to see if the engine light comes on before your car cuts out. because i'm pretty sure the computer can't diagnose the problem unless the engine warning light comes on, otherwise it doesn't know there's a problem. look for the light and if it comes on get it scanned or whatever they do. when i had the same problem i made the mistake of guessing what was wrong and ended up buying new plug, leads, harmonic balance, crank angle sensor, fuel pressure regulator and fuel filters ect all for nothing, My whole computer was cactus and i needed a new one. all the things i mentioned can cause your problem so make sure you find out what it is before you try and fix it.
    Feb 2010
    Thank for the help guys, I'll have a look when I catch up with my mate, cheers.
  1. Car Troubles...
    By justagirl86 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2011, 09:27 PM
  2. ABS Troubles.
    By fonzo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2010, 04:43 PM
  3. Big Troubles..S.O.S
    By thechubybear in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2007, 07:50 PM
  4. Car Troubles
    By theused084 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2006, 06:35 PM
  5. VH 253 troubles
    By Portunio in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-05-2006, 08:09 PM
