Results 1 to 7 of 7
Thread: vp ss help pulling my hair out with it
    vp ss
    May 2011
    cairns
    Default vp ss help pulling my hair out with it
    well the other day was driving the ss my speedo kept going up and down and then it and then the car just died and wouldnt strart back up seem like there was no spark half hour later she started back up didnt run good though then she just kept having trouble starting got it home did an error check got code 12 and went to start it back up it started at a real low idle and gradely got higher turn it off and havent been able to get it going since so thought it was ignition module replaced that and still nothing any ideas i checked the coil aswell theres spark there
    madreader222's Avatar
    madreader222 is offline Aero Rules
    Vp Aero
    Mar 2009
    Queensland
    My Vp did the same thing a couple of months ago and in regards to your speedo, mine was doing the same and no codes came up on mine until a week later and it was the Speed Sensor had shit itself, maybe check yours out.
    vamplestat is offline calais93
    VP Calais
    Feb 2008
    Australia
    just a random idea, but has it got a factory alarm installed? if so check the override switch as they have the tendency to fail and lock the immobliser on also check your CAS, "crank angle sensor"
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by nathan01 View Post
    Only other bit to go bung is the dizzy hall effect gizmo. The speed sensor may well be dead also - but should not stop the car from running.
    and 3 Dangerous non ABS VN's
    vp ss
    May 2011
    cairns
    it has a factory immobliser i dont have the remote but have the key for the side of the door turn it and said press remote which i dont have how can i override or turn it off permantly it cranking over goes to strart but doesnt
    vp ss
    May 2011
    cairns
    some ######## over filled my oil so was clogging the spark plugs thanks for everyones help
    Vp Aero
    Mar 2009
    Queensland
    Glad you got it sorted out.
  1. Hair Trigger Throttle
    By 88GreenVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-09-2010, 07:11 PM
  2. the hair thread
    By eurekamad94 in forum The Pub
    Last Post: 24-01-2009, 06:44 PM
  3. On the verge of pulling my hair out!!!
    By jayderichards in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-10-2006, 01:48 PM
  4. Your hair means the world to us
    By kowan in forum Jokes/Humour
    Last Post: 22-03-2006, 08:32 PM
  5. Tearing My Hair Out
    By lil_bonk_frog in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-03-2004, 01:39 PM
