Right, so I have a bit of a problem.. I am putting in puddle & footwell lights soon, but im down to a much more basic problem.. Recently, the interior light hasnt turned on when the doors are opened, yet it still works when the dome switch is pressed..
What could be causing this? Or where should I start to look?
Car is a VP sedan
Thanks
VKC
x2 on the door jamb switch... my back door needs one too...
dont sweat the petty... pet the sweaty...
unscrew the switch clean the contacts and spray it with some wd40 to free it up and it should be right.
But only one of the switches needs to be on (one of the doors open) for the light to go on..
All 4 used to work. I highly doubt that all 4 switches failed at the exact same time. I'll take a look, but I dont think it'll be it..
just open one door at a time and when your light dont turn on fix that switch
Only thing I can think of is the light for the key doesnt work (the bit that illuminates the key).. Maybe that is the cause of it..
this is a long shot vk, but have u tried the fuse? is your boot light also not working?
might be a stupid question but have you checked the globe?
