Results 1 to 9 of 9
Thread: no spark questions
    vp ss
    May 2011
    cairns
    Default no spark questions
    yesterday went for a drive in my vp ss and soon as i hit 80 to 100 km the car started shorting and wouldnt go past a hundred did it about 3 times and then it died and wouldnt start again check the spark and there was none coming from the coil so replaced it and there was still no spark what could be stoping it from getting spark and also replaced the ignition module recently and it not the imboliser tried that aswell
    VP Wagon
    Mar 2009
    check the loom to the coil pack some wiring could be cracked and shorting out
    vp ss
    May 2011
    cairns
    vp ss
    May 2011
    cairns
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Possible Crank Angle Sensor, they're a common fault on the V6 motors
    The 1972 HQ Kingswood
    vp ss
    May 2011
    cairns
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    ignition module check the connection and the underside of the module see if it's brown or black common fault for them to over heat and just give up
    Morton's Avatar
    May 2006
    Yeah, in that case either the Ignition Module or the Hall Effect Sensor in the Distributor
    Morton's Avatar
    May 2006
    Yeah, in that case, probably the Hall Effect Sensor in the Distributor Check the plugs, then remove the cap and check for broken pieces under the rotor button.
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. No spark - can someone help me fix it?
    By levymetal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2009, 06:20 PM
  3. Power steer oil & spark plug questions, please
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2007, 06:09 PM
  4. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
