Results 1 to 17 of 17
Like Tree2Likes
  • 2 Post By pjdm1980
Thread: My Kombi is overheating!!!!
    VZ SV6 Sedan and VN Kombidore
    Sep 2011
    Tallong, NSW
    Default My Kombi is overheating!!!!
    Hi,
    I have a 1976 VW Kombi Camper fitted with a VN (I think) Commodore V6 engine. The radiator sits on the front and has done an excellent job of cooling the engine...up until now.
    Over the past month the temp gauge has gradually risen each time I drive the van. Not boiling, but very hot. I suspected the thermostat and have now fitted a new one (old one was not closing completely). No change....still running hot.
    The situation is compounded slightly by the fact that the radiator is about 4 metres from the engine and connected via 2" copper pipes. I think the pump is working okay, as, with the cap removed and the engine revved, the water level drops. When running, the top hose is very hot while the bottom hose is only mildly warm. After the engine is turned off the bottom hose heats up. The engine also smells hot. Any suggestions or ideas?????
    Jul 2008
    Your names Jeff yeah ?
    If so that thing is ace !
    Your water pump may be on its way out, Radiator is cloged or its running very lean.
    Id just give it a good flush and replace the water pump and see if that helps, you could also consider adding an additional electric water pump to help things along a bit but the stock unit should do fine.. If it doesn't then its a whole new ball game.
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Sounds like your radiator is blocked, try a reverse flush
    if that don't work a replacement might be needed
    Sep 2011
    Tallong, NSW
    Thanks guys,
    There is a tap in the copper pipe underneath the van. This should allow me to drain the whole system and then I can attach a hose to that point and flush back through the system.
    Will give it a go...then might install a new pump.
    Cheers, Rob
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Remove the radiator to flush as you will flush all the shite back through the motor
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Sep 2011
    Tallong, NSW
    No pjdm1980 not that one....mine has a radiator on the front. I bought this one from my son, who bought it from the bloke who built it. Not sure how to post photos, but will have a go! Name:  Kombi Side.jpg
    I have flushed the system, which was perfectly clean anyway...no sludge, rust or dirt....just green cordial.
    I have now pulled out the water pump, and unfortunately it also 'looks' to be in good condition. I have ordered a new one and will fit it as soon as it arrives, but was really hoping to see an obvious problem with the pump.
    Does anybody know if there is a simple way to check the sensor? What coolant should I use when I refill the beast? Anything else I should be checking?
    Attached Thumbnails Attached Thumbnails My Kombi is overheating!!!!-kombi-side.jpg
    VS Stato l67
    Mar 2009
    Melb
    What a beast I'd love a camper like that. I went travelling in an Mazda e2000 on gas a while back. It had a solid 300k on the clock, and probably putting out 40 of the original 60kW. By the time you tied stuff to the roof, and put a few hundred kgs of gear in it the thing it struggled to pull 100km/h with my foot flat. A commodore V6 in that heap would have worked out nicely
    B-roca's Avatar
    B-roca is offline I’m an F-18, bro
    VE
    Jun 2010
    New Zealand
    Maybe its trying to tell you that it wants an LS1
    Jk, Good luck on resolving it mate, such a nice camper!
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    All i can picture is this thing pulling up next to me and a load of smoke coming off of one wheel and the sweet harmony of MANG MANG MANG!!!!!!!
    commodore
    Aug 2009
    australia
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Quote Originally Posted by pjdm1980 View Post
    hahahahah fkn lol.
    Sep 2011
    Tallong, NSW
    Yep, thermo fans are working perfectly. Heater also works perfectly.... but temp gauge sits just under the red and it only started doing this in the last month.
    Am still wondering about the temperature sensor!
    Sep 2011
    Tallong, NSW
    Well, I have spent hours trying to solve this problem! Have changed the thermostat, water pump, coolant, and cap after flushing the whole system. As of yesterday, the 'Big Girl' also has a new temp gauge and sender. Unfortunately, the gauge is still sitting just below red. The radiator blokes tested the block temp (140 deg F) with a laser thermometer, but the gauge is showing much higher (220 deg F). They also tested for leaking head gasket - no problems detected. Basically, they said they had no idea what the problem was or how to fix it.
    It was interesting that when I was revving the engine at 2800 rpm to get it hot, every 30 seconds or so the revs would drop for a couple of seconds (down to 2500 rpm) and then pick up again.
    Any ideas??????
  15. #15
    VP Exec
    Jun 2005
    What temp. does the engine actually achieve?
    If you can be sure that the coolant temp. sensor for the ECM is OK, the resistances vs temp. are listed in the "How To" on switching a VN cooling fan manually by immortality so you can check.
  16. #16
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
  17. #17
    commodore
    Aug 2009
    australia
    have you ran your hands along the radiator cores to feel for hot and cold spots indicating a half blocked radiator?
  1. Kombi VAn resto on ebay
    By Happydaze in forum The Pub
    Last Post: 17-02-2011, 11:09 PM
  2. Aaron Roberts' 20b rotary Kombi van
    By some_guy in forum The Pub
    Last Post: 29-07-2009, 07:49 AM
  3. v6 in a kombi
    By digger747 in forum General
    Last Post: 19-04-2009, 03:10 PM
  4. wtb kombi van adelaide
    By madvrcom in forum Swap / Wanted to Buy / Trade
    Last Post: 21-04-2008, 01:16 PM
  5. wtb kombi van adelaide
    Last Post: 07-04-2008, 06:54 PM
