Results 1 to 9 of 9
Thread: Vn 304 problem
    ibo
    ibo is offline
    Vn Calais
    Dec 2009
    Default Vn 304 problem
    Hey guys
    I got a problem with my vn 304, its starts up fine when it’s cold, but once the car gets pretty warm, the car just cuts off randomly and when you try to start it back up, the revs just go crazy and it cranks and cranks and she wants to fire up but doesn’t. Sometimes it back fires. Any ideas what this can be? I do have one injector leak which I haven’t not changed yet also I have changed the internal fuel pump with a 400hp one which by-passes the external pump (has been disconnected). Once the motor has cooled down it starts up fine. Help would be much appreciated
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Have you done a code check-
    Checking your Computer for Faults (VN - VP)
    ibo
    ibo is offline
    Vn Calais
    Dec 2009
    Nah i havnt make, funny enough i was just looking right now on how to do one will do it 1st thing tomorrow
    ibo
    ibo is offline
    Vn Calais
    Dec 2009
    i tried doing the code check and it doesnt work for some reason. I joined the black n white wires together and nothing happens.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Had a similar problem with a VP GTS years ago. Turned out to be a ECU fault. They are about $30 from a wrecker - Vn/VP V6/V8 are all the same. Just pop out the blue memcal and plug your one into it.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    vp ss
    May 2011
    cairns
    my vp ss was doing same thing ended beening the hall effect sensor in the distrubutor
    ibo
    ibo is offline
    Vn Calais
    Dec 2009
    how can i narrow it down to work out what it is? i dont want to spend money and change ecu and dizzy and find out it still occcurs
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i've been researching a suspected electrical problem in my vs 5L. and i've come across a few threads where people have had the same symptoms u got and its turned out to be a faulty hall effect sensor in the dizzy. mates vs 5L did the same a while ago too
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    ibo
    ibo is offline
    Vn Calais
    Dec 2009
    okay well to change the sensor is going to be a real pain in the arse coz of where its located :S. Any tips on the best and easiest way to change it?
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  3. Central locking Sv6 problem. this going to be a problem car??
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 10:40 AM
  4. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
