Results 1 to 14 of 14
Thread: engine mods?
    1988 Vn Executive
    Aug 2011
    ferntree gully
    Default engine mods?
    hey guys i gotta bout 800 bucks atm to spend and i wanna get more power out of my vn what things can i do
    VN S1 EXECUTIVE
    Sep 2010
    Margaret river
    exaughst, high ratio rockers, cold air intake and memcal to suit =) buy from mace enginering ( i cant spell for shit)
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    $20 fuel, rags, and a lighter.
    $780 in savings to put back in your bank for a real car.
    vamplestat is offline calais93
    VP Calais
    Feb 2008
    Australia
    Quote Originally Posted by Jackpole94 View Post
    that cursed word gets me everytime to lol
    VS Berlina
    Mar 2011
    Woodford QLD
    all for 800 bucks?
    1989 vn white
    Jul 2011
    Warranwood, Melbourne
    Quote Originally Posted by SlapNuts View Post
    Get fked some people like vn's
    commodore
    Aug 2009
    australia
    secondhand extractors ,new sports exhaust and cai and when you get more money put a decent cam and roller rockers in it.
    VP Calais
    Feb 2008
    Australia
    depends on your budget, i would suggest going to the mace site as they have all the best gear for the buick engine, iam plannning on going through them soon to do up my vp calais.
    VN S1 EXECUTIVE
    Sep 2010
    Margaret river
    i did it all for probably less thats with mates rates but. helps to know people
    VS Berlina
    Mar 2011
    Woodford QLD
    If I had a VN and 800 bucks I think I would take it to a dyno tuner and get them to make it run as well as it can now. A full and thorough service, replace plugs, leads, coilpak, filters, fluids etc, whether they need it or not, and service the fuel system. Then a good dyno tune.
    It may sound like not much, but get it done properly and you wont get much change from 800 bucks. People dont realise how much all the bits deteriorate without actually failing, and how much power they lose in the process. A serious service and professional dyno tune will transform your engine.
    If you've already done all that, then use the money to get a head job Clean the heads up, it will make a big difference.
    Too many people think about adding craploads of performance gear before even making the car run like it's supposed to standard. A car that hasnt had a decent tune in a couple years can lose 20-30% of its power, even more. Restore it to its former glory and you get an instant power gain of 30% ? Not too many other things can get you those kind of results so easily.
    commodore
    Aug 2009
    australia
    VR Berlina
    Jun 2010
    VIC
    if possible i would change the diff ratio. that would probably make u feel faster than anything else for less than 800 bucks
    VS Berlina
    Mar 2011
    Woodford QLD
    lol its a car forum a good head job will certainly cost that much. If it was a different kind of forum I wouldnt need to pay a cent
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    -Double row timing chain (remove balance shaft aswell, stops that annoying balance shaft bearing noise)
    -Ecotec oil pressure spring (will lower the chance of a rod going through the side because of lack of oil pressure)
    -Corvette servo, trans cooler and trans service
    -Replace engine oil, oil filter, spark plugs, fuel filter, air filter
    -Change diff oil
    -Greenfoam tune
    -100% throttle mode (in how to section), Might aswell clean the throttle body while your there
    -Change brake fluid (everyone should do this) and some hpx's off the gslrallysport
    -Replace Inlet manifold gasket and rocker cover gaskets
    and if you have any money left go to the wreckers and try and get some second hand extractors and a 2.5" exhaust
    Its best to get the car somewhat reliable before you mod it....
  1. vr engine mods
    By aussiebluVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2011, 10:41 PM
  2. VS 5.0L engine mods help
    By darky82 in forum V8 Development and Modification
    Last Post: 26-04-2011, 06:49 PM
  3. engine mods
    By vssleepa in forum Straight 6 Development And Modification
    Last Post: 07-12-2010, 12:02 AM
  4. vk 202 Engine Mods?
    By VK 202 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-10-2009, 01:56 AM
  5. engine mods!!!
    By vpdood in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2006, 11:21 PM
