Results 1 to 7 of 7
Thread: Auto box noises coming through floor when lever in "2" - something touching???
    VP Executive 5L
    Mar 2011
    Default Auto box noises coming through floor when lever in "2" - something touching???
    Was dawdling down the road at maybe 20kph with the (auto) shifter in 3rd not 4th and because the car was going so slow it was actually in 2nd. So far so good. Then I pulled it back to 2nd and the only thing that changed is the position of the shifter - box was still in 2nd gear. The difference was that now I could hear very plainly the whirry noises coming from inside the box. It was as if something was now touching the underside of the floor and transmitting noises by contact. Last time I looked I couldn't see anything obvious. Are there any rubber bushes on the gear linkage that go hard after many years or is there some way the linkage could be touching the floor and making noises come through?
    VP Wagon
    Mar 2009
    nup just the transmission mount but that would mean it'll be doing it all of the time, it could be the selector hitting the loom or something under there?
    VP Executive 5L
    Mar 2011
    Had a further listen to it tonight with the door open and the car stationary. Almost seems like the tranny makes a different sound when you slip it into "2". I suppose the fluid path in the valve body is different so it makes a different sound. Could someone else try it on their car and see if they get the same thing?
    Vp S IRS 6 Banger
    Jul 2009
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    vamplestat is offline calais93
    VP Calais
    Feb 2008
    Australia
    my auto box does this as well, but only when i hold it in first and second. has done it since i have had it, iam just guessing its just the different fluid pressure and gear ratios making a little noise. don't think anything is worn as it has a firm and crisp change and never lags in changing or when i engage it so iam just guessing its something the servers 2 vn transmissions do...
    VP Executive 5L
    Mar 2011
    Mmm.... just making it clear - got no issue with the box making noises in 1st or 2nd gear as such, just that if the box is =actually= in 2nd and the lever is moved from 3 to 2 and it is in 2nd gear both times because of road speed but the box sounds different. Odd... Hafta climb under and have another look.
  1. WM Statesman - "Contact Dealer" and "X Service" and Empty fuel gauge issues
    By selimlok in forum VE Holden Commodore (2006 - ?)
    Last Post: 13-11-2010, 07:15 AM
  2. VT calais "auto" headlights not functioning properly
    By muneey in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2008, 04:16 PM
  3. VT Calais "Trac Off" Light coming on
    By stirringaxe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-11-2007, 06:18 AM
  4. The "gears" and "power" in an auto
    By nath_120 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2006, 08:59 PM
