Results 1 to 6 of 6
Thread: intake manifold
    VN S1 EXECUTIVE
    Sep 2010
    Margaret river
    Default intake manifold
    hey is there a how to on how to clean intake manifold on a vn v6 s1 cheers. =D
    VS STATESMAN 3.8L 1996
    Aug 2011
    Albany,West Aust
    on the vehicle the inside can be cleaned with brake cleaner ($12)(Liqui-moly) or CARBIE+ MANIFOLD CLEANER ( Liqui-moly) just take on the intake pipe with a starscrewdriver .....this is the slack but effective way... or your can remove the manifold and use a car wash sponge and mineral turpintine($8.50L) or petrol ($1.50 L) then wipe it out a few times till acceptably clean then use methylated spirits to remove the min-turp residue then let is dry for a few moments and bolt back on
    ps. try to leave the accel. cables in its usuall position as much as possible but be e ven more careful when puting back on it is quite easy to get springs around the wrong way and such.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    If you want to clean the inside, you can use ThreeBond Engine Conditioner. It's designed to be injected into the throttle body while the motor is running, and soak into the carbon inside the plenum, dissolving it and allowing it all to be blown out via the exhaust.
    Brake Cleaner and Carby Cleaner won't do the trick on hardened-up carbon deposits, it'll just clean the dust off your carbon
    If you want to clean the outside, use elbow grease
    The 1972 HQ Kingswood
    Aug 2011
    Albany,West Aust
    morton, that seems the more practical approach.. but what about the catalyct converter, will this gummy it up? if not i know what's going in my next tank of fuel.
    Morton's Avatar
    May 2006
    Naaaah the ThreeBond stuff is designed to be safe for Oxy sensors and Cats. It's not put in the fuel tank, you literally spray it through any vacuum or emissions hose into your manifold while the car is running
    VN S1 EXECUTIVE
    Sep 2010
    Margaret river
    Cheers for your replys I might try that three bond stuff today
  1. intake manifold
    By stevesvx2001 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2010, 05:05 PM
  2. [SA] LS6 intake manifold
    By HRT 666 in forum Parts And Other Items For Sale
    Last Post: 30-04-2009, 07:43 PM
  3. air intake manifold
    By willyk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2009, 08:58 PM
  4. intake manifold???
    By 5.0L UTE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2008, 11:55 PM
  5. vs intake manifold on vn
    By hakhawk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2005, 09:22 PM
