Results 1 to 3 of 3
Thread: S1/S2 VN V6 mix&mtching?
    Manual Calais's Avatar
    Manual Calais is offline Manual VN Calais
    T5 VN Calais 3.8
    Sep 2011
    Bendigo, Victoria
    Default S1/S2 VN V6 mix & matching?
    What problems may you encounter when mixing and matching say s1 block wit s2 heads/inlet manifold or the other way around?
    VC
    Oct 2008
    I have S1 with S2 heads, you will need to block two holes on the inlet face of the heads with welsh plugs and a bit of work on the inlet manifold where the welsh plugs fit if you are going to use a S1 inlet manifold on the S2 heads.
    T5 VN Calais 3.8
    Sep 2011
    Bendigo, Victoria
    wat about s2inlet and heads, then just block the two holes?
Tags for this Thread
