Results 1 to 6 of 6
Thread: How do you tell if the water pumps stuffed..
    vn head's Avatar
    vn head is offline 89 VN calais all the way
    89 VN Calais..Older and Bolder
    Jul 2011
    christchurch,new zealand
    Default How do you tell if the water pumps stuffed..
    Hi there Ive got overheating problems I checked the termostat after getting to it there was no thermostat someone took it out before me.
    How do you know if the water pumps had it,there's no water leaking from it.I did replace the water pump three years ago but it was a aftermarket cheapie..
    when it was overheating there was water and pressure trying to get out of the top radiator hose where it joins on to the radiator.
    thanks..
    89 vn calais 3.8 stage 1..
    90 vn wagz and 90 vn sedan
    Feb 2010
    Is there water leaking from underneath the engine? Thats how I knew mine was stuffed, went to replace it last night with the one off my donor engine and I had to drop a bolt on the grass -.-
    With great cars, comes great drivers.
    vn head's Avatar
    Jul 2011
    Quote Originally Posted by havavb View Post
    No water leaking,the waters comming out of the radator where the hose joins on at the top this has got me stuffed I just replaced the radator.
    Did you find your bolt!lol
    vn head's Avatar
    Jul 2011
    All good on the over heating problemIt turned out to be the radiator the bastard is made out of plastic, where the top radiator hose joins on to the radator its all cracked.
    Putting the themostat cover back on was a mission..lol
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    you should put a new thermostat in too.... there in there for a reason and a engine will run hotter without one in
    If in doubt......FLOOR IT!!!
    Feb 2010
    Yeah I pulled my thermo stat's apart when I changed water pumps and found I had no thermo stat that's why my engine was heating up, yeah I found the screw after about an hour of searching lol. Then snapped one of the small bolts screwing it in so I used extra gasket goo and rammed it in where the screw would go (half a screw in the water pump, and it doesn't want to come out) haha.
LinkBacks (?)
  1. 02-12-2011, 10:18 PM
  1. electric water pumps
    By dagsy in forum V6 Development And Modification
    Last Post: 02-10-2010, 07:01 PM
  2. VN and VR water pumps.
    By Butcher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2010, 11:50 AM
  3. After market water pumps
    By GIMPEESS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-02-2007, 07:13 AM
  4. Water Pumps?
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2006, 05:01 PM
  5. how do i know if my water pumps on its way out ?
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2005, 09:36 PM
