How do I replace the bulb in the Dome & Mode buttons located next to the Windscreen wiper switch in a 1992 VQ Statesman?
There is a thread how to change the bulb colors.. I will try to find it for you.. Think you need to pull it apart
you have to remove switchblock from dash pretty easy 2 screws under switchblock 2 screw in dash above the cluster this will remove whole "surround" then unplug your switchblock remove retaing nut at back and its out now your up to the hard part you have to dismantle some parts of switchblock to get at the globes pretty sure theyre T3 globe maybe greenvn or someone else will confirm mightactually be the same as the warning lights on cluster
Originally Posted by Smidy
Hi, Thank you it worked out well, your right they are T3 globes. The only hardest thing was when I screwed the switchblock back together I had to take it easy because some some of the screw threads were half splitting even though I tightened them up not very tight at all. Thanks.
