Results 1 to 9 of 9
Thread: vn T5 Heavy Duty Parts?
    Manual Calais's Avatar
    Manual Calais is offline Manual VN Calais
    T5 VN Calais 3.8
    Sep 2011
    Bendigo, Victoria
    Default T5 Heavy Duty?
    Hi all,
    I have a T5 in my vn, and recently the imput shaft bearing has shat it self and ive got a price of 730 bucks to run a bearing & seal kit through it. I've also been test driving a few vn manuals for sale because ive been thinkingto just swap the box over. what I have noticed is all the other manuals ive driven have felt different to mine, mine feels more 'heavy duty' in gear changes. Im just wondering how you would tel if you have heavy duty parts in your gear box? and what they might be so i know if itsd worth rebuilding the one i have or swapping it over.
    Thanks
    GRPABT1's Avatar
    GRPABT1 is offline Jakstas' Warden
    VN shitta
    Sep 2010
    The ville
    Your T5 is no different other than the condition, others may be more or less worn. Other than cryo treating there is no way to beef up a stock T5 which you would never feel. Dog engagement sets are available now apparently but you would definitely know if you had one. If testing a box out for swapping then load it up in a gear (low RPM full throttle) and quickly let off the throttle, do this a couple of times and if it pops out of gear don't buy it lol. Also listen for whining noises under power and idling with the clutch in, in every gear. And obviously if any gear is difficult to select then there is a problem. Typically 3rd gear blows in a T5.
    Cheap, fast, reliable.....you only get to choose two.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Your T5 is likely standard. What 'may' be different is you may have a heavier duty clutch fitted with a stronger pressure plate, giving you a heavier feeling to the clutch pedal. No way to tell for certain without looking at it. Even then it may be hard to identify if it doesn't have any obvious markings etc on it.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    T5 VN Calais 3.8
    Sep 2011
    Bendigo, Victoria
    i have a heavy duty clutch but would that change how it feels through the gears at the stick?
    T5 VN Calais 3.8
    Sep 2011
    Bendigo, Victoria
    Morton's Avatar
    Fairstar the Funship
    May 2006
    The infamous T5 whine that the previous poster refers to is a sign of the webbing in the gearbox housing beginning to fracture, rather than intetnal components. There is nothing that can be done to really strengthen internals, although T5g boxes ran a fine spline input shaft to spread clutch loads over a greater surface area.
    The 1972 HQ Kingswood
    micsnaffled's Avatar
    micsnaffled is offline micsnaffled
    VH 355 V8 5.8litre
    Sep 2005
    South Melbourne
    Group a ss, some ss had shot peened gears.
    That's the only t5 box that got any treatment. I've heard... Thought it came out with an Italian made zf 6 speed?? Anyway...
    I've just rebuilt my box, finished 1 day ago and there is heaps of things to make it stronger!!
    For eg: new tremec bearings, syncros, seals, major rebuild kit. I had billet keys put in most gears instead of the pressed whatever crap they had in there, also had billet selector pads for the forks again instead of the crap that was there. Also had a billet front bearing gear retainer slapped on to stop gear movement under heat, all my gears and working parts have been shot peened. Had the gm rip shift put on for the straight gate
    2 to 3 gears. Billet shifter bush on the base of the short shift replacing the plastic item. Mmmmm
    Maybe a couple of other small things but should be able to handle 500hp
    Plus a bit more!!!
    I don't think your box is different at all unless it's from a vn ss
    But mine cost me an arm a leg and a testicle $2,000 twin plate clutch included!!!
    If you need any body for parts just let me know, I had one guy try to charge me the same $700 for 2 parts... Ended up by getting them from tremec for less than 1/2 price all brand new tremec!!! I paid $306.54 for the same 2parts!!! Be careful!!
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    OP the reason your box more than likely feels 'heavy duty' it because its got regular gearbox oil in it, rather than ATF. The gear oil could also be the reason for your input shaft bearing failiure.
    World class t5s (all t5s in commodores are world class) have needle bearings in them and 3 peice fiber synchros, which is why they need ATF in them.
    Non world class t5s have brass synchros (not sure what bearings) so they run normal gear oil.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    VH 355 V8 5.8litre
    Sep 2005
    South Melbourne
    Here
    That's the finished product as stated earlier! All mods, brand new!!
    Attached Thumbnails Attached Thumbnails vn T5 Heavy Duty Parts?-image.jpg   vn T5 Heavy Duty Parts?-image.jpg
  1. [QLD] VS tow bar heavy duty
    By Decicrate in forum Parts And Other Items For Sale
    Last Post: 18-01-2011, 11:23 AM
  2. Standard Duty VS Heavy Duty - Pedal Feel
    By Tom_1569 in forum General
    Last Post: 25-08-2009, 10:43 PM
  3. Heavy Duty Clutch
    By ecotec38 in forum General
    Last Post: 21-08-2008, 11:59 AM
  4. rpm heavy duty clutch
    By 5speedcalais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2006, 01:10 PM
Tags for this Thread
