Results 1 to 8 of 8
Thread: help!!! car wont start
    vn executive series 1 v6 1989
    Sep 2011
    maryborough
    Default help!!! car wont start
    i own a 1989 vn commodore series 1 and it was on gas but i removed it because it was buggered needed 2 have all the gas lines redone and bottle restamped so i removed it.. the bottle and the lines came out fine but i got to the ecu area and cut out all the wires for the gas but not my car wont start. i changed the engine loom because i thought i cut some thing i shouldnt have but it still wont start its getting spart and turning over but just wont fire
    VK -Project-, VX R8 Clubsport
    Feb 2010
    Tamworth NSW
    are you getting power to your fuel pump ? sounds like you might have cut a wire to it
    Sep 2011
    maryborough
    Vn Vacationer
    Jan 2007
    Check for power at the pump connector, if no power check the fuse and see if the relay is working. If there is power maybe the pump has packed it in if its been using only the gas for a while
    Vt calais v6, VN Exec on nitrous budget skid car
    Jan 2011
    Australia
    i also have the same problem with my vn station wagon, removed the gas system and the car wont start, i have fuel at the rail, spark etc im thinking maybe with gas systems they wire something in to cut injector pulse? question is where do they tap into the car to do this? anyone with any experience with gas systems provide any feed back?
    Sep 2011
    maryborough
    i had the same problem i changed the engine loom because i couldnt figure out what they did with changing wires and soldering stuff in.... thak god the gas is gone tho... im pritty sure they wire it up so when its running on gas the ecu stops sending the pulce 2 the injectors but i found this out after i finished
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    check for power at the injectors , the most common injector cut was at c 14 and c 15 wires at the ECU , depending on what system was wired in before hand there might have been external relays fitted or the lpg module had internal relays . also a fuel cut relay may have be used or not , any info on the lpg system that was fitted would be a good start
    90 vn wagz and 90 vn sedan
    Feb 2010
    Did it have a switch that could choose between: gas, fuel, and nothing (security purpose I suppose). My mate had one and the car wouldn't start, turned out it was switched to nothing, cause maybe you left that on gas, or nothing.
    With great cars, comes great drivers.
  1. New Key now car wont start and cuts out when km's on cluster start flashing :(
    By rowiejoan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2011, 10:44 PM
  2. vs calais wont start unless i kit unlock before i start
    By scottmcguinness172 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2011, 06:40 PM
  3. vr wont start
    By bear76 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2010, 02:46 PM
  4. Vr V6 Wont start...
    By hdt 01 in forum Electrical Wiring / Questions
    Last Post: 07-04-2008, 07:39 PM
