Results 1 to 4 of 4
Thread: tailshaft problems????
    91 vn ss
    May 2011
    brisbane
    Default tailshaft problems????
    hey guys i just pulled my tailshaft out to replace the cetre bearing and when i pulled it apart i replaced the rubber mount bearing but there is another big bearing right where the join is on the inside and its screwed so i want to replace it but none of the regular parts dealers have it. can any1 help me with somewhere i could get 1 from??
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    You mean the driveshaft cv? how is it screwed?
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    91 vn ss
    May 2011
    brisbane
    yea thats what i meant lol 1 of the balls out of the bearing was missing when i took it apart and the bearing casing is broken a bit
    GRPABT1's Avatar
    GRPABT1 is offline Jakstas' Warden
    VN shitta
    Sep 2010
    The ville
    A driveshaft/CV specialist should have one. Hardy spicer should.
    That centre bearing rubber mount is the shittest design too. I flogged out a bunch of them, some in a matter of just days beforemaking a custom mount that holds a modified land rover bearing encased in alot more heavy duty rubber and then filled with sikaflex.
    Cheap, fast, reliable.....you only get to choose two.
  1. Is the vx v6 tailshaft the same as the Gen3 tailshaft ?
    By comfortss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-07-2011, 11:48 PM
  2. Vn v6 manual tailshaft problems
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-02-2011, 09:16 AM
  3. vl tailshaft/diff problems
    By 88-SERIES200 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-05-2010, 09:53 PM
  4. separating tailshaft and tailshaft lengths
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2008, 08:18 AM
  5. Tailshaft Problems
    By DanVnVh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 05:39 PM
