Results 1 to 5 of 5
Thread: Transmission won`t shift into 3rd gear//no power in 3rd gear
    VN Berlina- Stationwagon
    Oct 2011
    Default Transmission won`t shift into 3rd gear//no power in 3rd gear
    Hey everyone,
    I am hoping to get some advice from you with my problem.
    A few days ago my car stopped changing from 2nd gear into 3rd gear or maybe it just seems like it to me. At around 50-60kph, when it should shift into 3rd gear it starts to idle really high and doesn't bring any power on the road, almost seems to be in neutral. I can manually put it back in 2nd gear and it will stay in 2nd gear when I change it into D while keeping the load on the transmission, but won`t change into 3rd gear at all ( I drove up to 80kph but still didn`t change).
    I have to say that I was low on transmission fluid for about 10km before the problem started. During that time the transmission might have been damaged. I topped the fluid up and ever since have that problem.
    Is there a chance that I clogged up the filter when running low on fluid? Also I got a little leek one of the cooling pipes going into the transmission, but I had that since I changed the transmission about 2 month ago. Could that lead to a pressure problem in the transmission?
    Thanks a lot guys.
    91 vn s
    Jun 2009
    Adelaide, SA
    might have cooked a clutch pack pr something, a job for the professionals - give any autotrans place a ring. OR this mob Gawler Autos (8522 2558), even though you are in melbourne, these guys will know the answers to pretty much any trans related question u can ask.
    The small leak from the cooling pipes wouldnt affect it. Ive got a seeping union at the trans cooler and that doesnt affect the car at all.
    hope this helps
    VP Executive 5L
    Mar 2011
    I had a similar problem with a Trimatic. The vacuum line to the modulator fell off and made the tranny think it had full throttle 24/7 so it was reluctant so upshift. The air leak into vacuum line made it idle bad but on an EFI car it would just idle fast.
    ibo
    ibo is offline
    Vn Calais
    Dec 2009
    Hey mate i had the same problem a few months ago. I was driving and when the car hit 60ks and change into 3rd it would just rev like it was in neutral. Iv lost 3rd gear and i think you might as well.. your going to have to take it to professionals and get it checked out
    Oct 2011
    Thanks for the answers.
    I changed my transmission fluid and put a new filter in. I hope that will help and the problem fixes itself. Otherwise I probably have no choice but to go to the wreckers and look for a 'new' transmission. They are a 110$ with torque converter, so I might give it a shot.
  1. 3rd Gear shift
    By eddy_eddy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-08-2009, 08:09 PM
  2. Gear Shift On An Auto,
    By Terence in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2009, 05:30 AM
  3. 3rd to 2nd gear shift
    By mina_783 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2007, 01:51 AM
  4. Gear box / shift kit in statesman
    By HIROLLA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2006, 10:48 AM
  5. Shorten VT1 Gear Shift - Can it be done?
    By davus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-01-2006, 05:13 PM
