Results 1 to 3 of 3
Thread: VN trailing arms help please
    JGlinatsis is offline Ratty
    Vr Executive 3.8 V6
    Apr 2009
    Default VN trailing arms help please
    hello I have changed everything in my car to nolathane and I was just wondering about the trailing arms the bold wont line up about a inch out i was just wondering if i have to take something off to get it to line up, example pan hard rod, lower control arms, or if its the way i jack up the car or what please let me know im doing all this for a roddy on my VN group A mock
    GRPABT1's Avatar
    GRPABT1 is offline Jakstas' Warden
    VN shitta
    Sep 2010
    The ville
    What trailing arm/arms are you doing, uppers, lowers or both?
    Shouldn't need to remove anything to fit them, if you have removed the old ones already then the diff would have rotated somewhat most likely making the distance between the mounts different. You just need to get the diff housing rotated to the position where the arms fit. You will need the car jacked off the chassis rails though not the diff housing.
    Cheap, fast, reliable.....you only get to choose two.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Best order of assembly:
    1) lower arms to diff and chassis
    2) locate springs and raise diff
    3) upper arms to chassis
    4) raise + rotate diff and bolt upper arms to diff
    5) swaybar
    6) shocks
    7) brake line fittings, handbrake cables, etc etc.
    The 1972 HQ Kingswood
  1. rear upper trailing arms
    By sprayzz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2011, 03:22 PM
  2. [VR-VS] How to replace lower and upper trailing arms
    By SP00KSTER in forum Holden Commodore How-To's
    Last Post: 01-08-2011, 07:20 PM
  3. upper rear trailing arms vn
    By ybl8te in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2010, 05:01 AM
  4. [VIC] VP IRS rear trailing arms c/w discs, calipers etc
    By vp_exec in forum Parts And Other Items For Sale
    Last Post: 05-05-2010, 03:49 PM
  5. Upper trailing arms
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2007, 08:47 PM
Tags for this Thread
