Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By <RaBBiT>
Thread: Sticking roof lining back
    None
    Apr 2010
    Default Sticking roof lining back
    Hello all,
    I'm after something that can stick not only the roof lining back up, but the wood stuff (I have no idea if it's wood or not, looks like it and feels like it in a way) back up that's under the lining itself. Here's the extend of the roof lining problem:
    As for the 'wood stuff' that's also coming down the best way to describe it is that it's the stuff under the roof lining itself. The lining and 'wood stuff' is only is only falling down at the back of the car where pictured so I don't think replacing it with a new one is even worth it as it can be fixed from what I can tell.
    Forgive me If stuff under the roof lining isn't wood, just looked like it to me
    Edit: A picture to better describe it:
    Thanks.
    <RaBBiT>'s Avatar
    <RaBBiT> is offline Follow the White RaBBiT>>
    95 VS Berlina 5.0,VN Wagon 5Spd 5.0L
    Nov 2007
    [SA]
    Nah it's not wood it's cardboard and it held up by Velcro be easy fix hope that wat ur after
    If Barbie's so popular, why do you have to buy all her friends?
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    If it's coming down in one place I'd think it will start to come loose elsewhere soon too. Sticking in back up with kwik grip will work for a while but the foam usually falls apart and won't glue reliably. A bodge that will work until you can be bothered changing it over is to use drawing pins into the cardboard. Auto upholsterer will charge about $150 to put new foam in and glue it all up properly but you'd have to take the lining out and install yourself.
    Warranty Void
    None
    Apr 2010
    I'll give the kwik grip thing a shot first, cheers.
    89 vn calais v6
    Oct 2010
    when mine started falling down i just went to a pick a part and checked all the cars till a found a good one. cost me $36 its been more than a year and had no problems at all.
    None
    Apr 2010
    Had a mate check it out today when he came around, apparently I'm missing the trim at the back near the back window that holds it all up (I didn't even notice) which is causing it to fall. Make sense because that is where it's falling from.
  1. [SA] FS: Complete VQ Roof Lining + Caprice Roof Bits
    By PREDATR in forum Parts And Other Items For Sale
    Last Post: 21-07-2009, 06:10 PM
  2. Roof lining
    By BradCalais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-12-2008, 11:45 PM
  3. roof lining
    By Archers in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2008, 12:20 AM
  4. roof lining
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2007, 12:18 AM
  5. roof lining
    By 81_vh_holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-07-2006, 06:22 PM
