Results 1 to 3 of 3
Thread: [Help] Checking for errors in vn.. which wires?
    89 VN Berlina 5sp 3.8
    Apr 2010
    Default [Help] Checking for errors in vn.. which wires?
    Hello, I read the guide on how to check for errors in the vn by bridging it with a paper clip.. I'm having difficulties finding which ones to bridge... i removed the kick panel to expose the metal case holding the memcal. I have no idea which ones to bridge.. is it 1 of the 2 cables plugged into the bottom of it? theres also some hanging above the case not plugged into anything. Nearly all of them have A white and A black wire. So im so confused which ones to bridge. I need a bit of an idiot guide or description. Cheers guys
    vs commodore
    Oct 2009
    Tamworth NSW
    Its the plug just above the ECU thats not plugged into anything. It has 6 pins. When you find the 6 pin diag plug, you then need to find the White/black wire (Pin A on diag plug), and also the Black earth wire (Pin B on diag plug) and then connect these two pins with a piece of small wire or similar.Turn the ignition key on and the check engine light should flash up any logged codes, or if no codes are logged, flash up a continuous code 12.
    Note- just remember that pin A pin and pin B etc is not actually marked on the diag plug, its only shows which pin is which in the workshop manuals,but if you just go by the wire colours, you cant go wrong.
    Apr 2010
    Quote Originally Posted by Brett_jjj View Post
    Thanks heaps mate.. Very much appreciated. Will do that first thing tomorrow.
  1. VR BUICK COIL PACK WIRES + and - which wires???
    By H1GHROLLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2010, 09:32 PM
  2. VT V6 errors need help
    By dammit_billy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2009, 01:53 PM
  3. checking code errors on VY LS1--detailed
    By Joey_21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-11-2008, 10:50 PM
  4. Checking Errors + Rough Idle/Start
    By D34N in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2008, 04:43 PM
  5. CAS Errors....again
    By dj_eddie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2008, 06:13 PM
Tags for this Thread
