I recently purchased a pair of VP Calais rear arch spats and I'm curious to know if anyone has had any success putting them on a Berlina?
I don't have the brackets they usually sit on as they're spot welded to the car.
The side closest to the bumper seems pretty straight forward, but the other side closest to the rear doors has no where to drill/pop rivet onto.
Any ideas are greatly appreciated.
Either get factory bracket s or make ur own and weld them on
If Barbie's so popular, why do you have to buy all her friends?
would be pretty easy as its three 10mm bolts through a piece of steel.... i skipped all that mess and just bought a calais
dont sweat the petty... pet the sweaty...
Are they going on a vn or vp berlina?
will be inerested to see how yo as I have a exec tryed getin on but they seemed to sit funny was a gap and also have a senator kit on mine. So I ended up getin rid of em.
go to the original car drill out the spot welds, remove plate and weld it into your belina done.
All the door moulds/chroming/pin stripe what ever you got will line up fine, it the VQs that dont match as the chrome's lower and on the VQ its higher
They will be going on a VP Berlina and yes they line up perfectly with the bumper/door moulds.
Looks like I'll have to look for a pair of brackets now.
eBay Australia: Buy new & used fashion, electronics & home d
Just found these on ebay. Looks like they have 2 upright bolts to go straight into the lip of the guard. I guess no bracket is needed!
VT Ballin'
back in the days when i had my VP, i bought the spats as well. My VP was an exec and i just used self tapper screws on either ends and the top to hold it in place. Just note that (i'm not sure for berlina's), but the spats from the calais don't match up with exec's (maybe berlina's too). but my old VP was white and i took all the door strips and everything off so you couldn't really tell that it didn't match. I wouldn't bother with getting a bracket.
Looks weird without the door trims.
did look weird with the spats on there which why i ended up taking them off, just didn't match anything on the exec. not sure if Pickled has same issues on his berlina.
my berlina could use a set wanna sell them to me?![]()
