g'day, my tps and o2 sensor is rooted in my vn, ive got a vr sitting in my driveway thats not used anymore but its dual fuel.. would the sensors fit out of that just as a temporary thing till i can grab new 1s?
Throttlebodys on the V6 VN and VR are practically the same, so yes the TPS should be a direct swap.
o2 sensor will work, some say VR's run a 4 wire o2 (two of those wires are just to heat the sensor on cold starts, you don't need to worry about those) where was VN's definitely run just a 2 wire o2 from memory.
Cheers for that. Swapped em over and everything is runnin perfect. Cheers guys
