Results 1 to 6 of 6
Thread: Brake Light Pedal Sensitivity (Or there lack of)
    Holden Commodore VN
    Sep 2011
    Auckland
    Default Brake Light Pedal Sensitivity (Or there lack of)
    Hi There
    I own a 1990 Holden Commodore (Berlina) VN series. I am just having a small problem with the sensitivity of the brake lights when I put my foot on the brake. It does light up but needs to be pushed quite hard and most of the time I use light engine braking so it never really gets the pressure it needs for the brake lights to even light up. Im wondering if this can be fixed with a screwdriver/spanner etc or is a little bit more involved. If you could let me know that would be fantastic!
    Regards
    Matthew Lovemore
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    posted in the wrong section entirely!
    best of luck with this one and next time please read the forum your posting in before just dumping it there and hoping for the best
    VN S1 EXECUTIVE
    Sep 2010
    Margaret river
    VZ Wagon
    Jun 2011
    Brisbane North
    I believe you will find the brake light switch under the dash against the brake pedal.
    Check if it is sticking and maybe spray it with WD40 or similar, or it may need adjusting/replacement.D
    s1 vt
    Jul 2005
    you can buy them brand new for cheap just swap it out and then align so slight pressure make it go open circuit.
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    the pressure switch is threaded and screwed into bracket behind the pedal. it might have worn out and jumped a few threads (as its plastic) making you have to push harder to engage the switch. either readjust, or just replace it.... just stick you head under the steering column and have a look...
    dont sweat the petty... pet the sweaty...
  1. alright so, brake pedal = parkers on front and rear brake light. head lights on and..
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2011, 08:29 PM
  2. brake lights not coming on until brake pedal almost to floor
    By zskinner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2010, 07:11 AM
  3. Put Manual Pedal Box In, Now Brake Pedal Is Stiff, Quick Replies Please
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2009, 09:01 PM
  4. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  5. Low brake pedal.
    By edgar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2005, 12:25 AM
Tags for this Thread
