Results 1 to 6 of 6
Thread: Failed brakes
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Default Failed brakes
    Hey guys,
    Trying to diagnose what the problem is with my brakes and could use a bit of advice on what the problem is before I go replacing perfectly fine parts.
    Started the car today, put the foot on the brake pedal and all I could hear was a loud hissing noise coming from behind the dash. Went for a quick drive and i figured out pretty quickly that the breaks are screwed when I put the pedal down as far as I could and it barely made it passed what I would call gentle braking.
    Changed brake pads yesterday and there didn't seem to be any problems. Didn't disconnect any hoses so there shouldn't be any air in the system and I was careful so that I didn't damage any hoses. Haven't lost any brake fluid out of the reservoir either.
    If I put the foot on the brake pedal with the engine off and turn the engine on then the brake pedal depresses. When the engine is turned off it pushes up again very slightly. Also when pushing the brake pedal down while the engine is running the revs increase and then drop again when the brake pedal is released. I've tried blowing into the check valve on the brake booster and it would allow air through when blowing from the booster side but doesn't allow air from the intake side.
    I'm pretty sure this means my booster is cactus but I would like to hear some other peoples opinions too.
    Cheers,
    Jarrad
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    illegal_____ is offline Banned
    vp commodore
    Dec 2010
    sydney
    did u take resovir lid of when changing brakes and depressing piston back?
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Yeah popped the lid off, made sure the rubber thing inside the lid and the lid were back on properly too. Checked it a couple of times now actually, I was really hoping for an easy (cheap) fix haha
    1. 1990 VN Exec V6
    vp commodore
    Dec 2010
    sydney
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    No as I hadn't exposed them. I just undid one of the caliper bolts and loosened the other so that the caliper could be lifted up exposing the pads and keeping everything else in place
    1. 1990 VN Exec V6
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Took a chance and went out and got a second hand booster. What a pain in the ass to fit, was all easy until it came to those two nuts behind the dash. Was definitely a dodgy booster though as the new one works perfect, car really pulls up well now.
    1. 1990 VN Exec V6
  1. VS brakes just failed!
    By and3rs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2011, 06:24 AM
  2. failed
    By 5lcalais in forum General
    Last Post: 24-09-2010, 08:27 PM
  3. VN S1 odometer has failed
    By hemi01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2007, 12:43 PM
  4. My brakes failed today..
    By ProMaX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2006, 04:55 PM
  5. failed RWC
    By Philth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2005, 09:41 PM
