Results 1 to 3 of 3
Thread: doing a flush of the radiator...vn series 2
    vx wagon exec
    Jun 2011
    Nsw
    Default doing a flush of the radiator...vn series 2
    ok so im just wondering what the best way of flushing out my system is.
    also while im doing this i would like to change my thermostat since i have been having overheating problems so wondering were it is located?
    tahnks
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Yeah the best way to flush a radiator is from the bottom, up...
    So if I was really bored and wanted to do a good job, id firstly drain the old stuff, fill it up with tap water and run the car for 5 mins, drain it, wait for it to cool down, add more tap water and a radiator flush fluid through the system and then take it for a spin for another 10 or 15 mins, drain the water again, remove the radiator and flush the rad with a hose from the bottom hose upwards for a few mins...
    The thermostat should be easy to locate. If you look at the top hose, follow it towards the engine, and the dome looking thing that the hose clamps onto should have two 10mm bolts.. Undo that and its under there...
    vn wagon cross fc wagon
    Jul 2011
    cambooya qld
    undo one of the heater hoses. stick the garden hose inside the heater hose and turn the heater on, turn the hose on and it will flush the heater and engine at the same time.
  1. Trying to flush this radiator
    By BadJesse in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-01-2011, 06:27 AM
  2. flush radiator VY V8
    By lowrider in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-07-2010, 11:36 AM
  3. flush radiator VT Series ll 1999
    By badgez in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-05-2010, 08:07 PM
  4. how to flush my radiator
    By GeorgeB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2005, 04:52 PM
  5. Radiator Flush
    By MySV6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-11-2004, 02:17 PM
