Hey guys, anyone know the size of the bolts the join the trans mount to the body?
1. 1990 VN Exec V6
2. 1993 VP BT1 3.8L - Now wrecking for parts!
3. 1991 VP Berlina V8 - RIP
Looking for a good condition VN - VS V8!!!
These come out pretty often if the thread into the alloy is stuffed. You can get some slightly longer bolts and nylock nuts and drill through the alloy and fit right through = last time you will see the problem. Alternatively the wreckers is your friend.
Warranty Void
Ended up putting a jack under the trans so I could take the other bolts out and match them up at coventry fasteners. $2 later and all sorted.
If anyone else is interested I used M10 x 25mm hex head and M10 x 15mm Cap Screws.
1. 1990 VN Exec V6
