Results 1 to 18 of 18
Like Tree6Likes
  • 2 Post By monkeys437
  • 2 Post By NIXONLS1
  • 1 Post By Tim Smtih
  • 1 Post By monkeys437
Thread: holden vn
    vn s1
    Oct 2011
    Goorambat
    Default holden vn
    i have a problem wif my vn it jerks and idk y ?
    VS Stato l67
    Mar 2009
    Melb
    Well given your detailed description of the fault im confident someone will be able to help you
    vn s1
    Oct 2011
    Goorambat
    it dose it most of the time 3,500 to 4 but it will never go over 4,000 and in top gear it dose it at 2,000 i change the plugs fuel filter
    NIXONLS1 is offline Banned
    my mum
    May 2009
    Bansville
    spauldj308's Avatar
    spauldj308 is offline S Pack Man
    VR S sedan 5L, VSII ute
    Oct 2005
    Hobart, TAS
    Air filter blocked?
    VR II S sedan - Genesis Blue - Cammed 304 - T5 - 19's - Weekend warrior
    VS II S ute - Diablo Red - V6 - Getrag - Daily Hack
    vn s1
    Oct 2011
    Goorambat
    i dnt flog it just seen wat it would do and it did that and it alaway dose it at 100 at 2,000 na just put a pod fiter on
    VN Excecutive
    May 2011
    South Australia
    Quote Originally Posted by NIXONLS1 View Post
    Bloody hell, you sure do sound like a vn driver...
    com bruv der na all lik dis, all s mob tak like a boss
    We live in a society where pizza gets to your house before the police.
    few commodores
    Feb 2011
    victoria
    start with the basics, plugs (done), leads? (test with a multi meter), fuel pump? (see if you can get someone to check it's pressure), faulty fuel pressure reg?.
    alternatively try running a tank of e10 or 95-98 octane in it with a bottle of injector cleaner through it, as it's a vn it's pointless to run it on that stuff all the time.
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    I had this problem. Check to see if the vacuum lines, specifically the one from your map sensor is cracked, if so replace it. The ends of mine were cracked so i took 7 odd mm off each end and the car ran fine after that.
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
    vn s1
    Oct 2011
    Goorambat
    Tim Smtih's Avatar
    Sep 2009
    Here.
    Are you sure your keyboard isn't broken too, either that or upon entering this thread i've suddenly become dyslexic.
    Albert Einstein
    vn s1
    Oct 2011
    Goorambat
    VS Stato l67
    Mar 2009
    Melb
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    "everythink" hey???
    back in primary school (grade 2 or 3 maybe), i was taught to spell it with a G at the end..
    P.S, MAD pod filter skidzz
  15. #15
    vn s1
    Oct 2011
    Goorambat
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    You should change your user name to Mangvn insted of Hangvn .....
    Originally Posted by 87RB30VL
    Huh? I got given the gun of my neighbour,
  17. #17
    VS Stato l67
    Mar 2009
    Melb
    Quote Originally Posted by hangvn View Post
    where about is that sensor ?
    Gregorys service manual is the best investment you will ever make my man.
    Best part is it has good pictures for those among us that struggle with long words
  18. #18
    Tim Smtih's Avatar
    Sep 2009
    Here.
    As above, please get a good service manual. Most have detailed pictures and diagrams and with tthe flick of a few pages you can have all the answers you need without copping flak from randoms for your lack of teh typing skillz. MAP sensor is on the fire wall on the passenger side, go go gadget google pics......
    TA DA!
    Albert Einstein
  1. VL Holden Wheels wont fit on Trailer with Holden Hubs WTF?
    By Gazza2005au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2011, 10:51 PM
  2. [NSW] FS: Factory Holden 5 speed conversion for VB-VK with Holden 6
    By vh_thunder in forum Parts And Other Items For Sale
    Last Post: 27-07-2009, 09:10 PM
  3. Replies: 14
    Last Post: 13-07-2008, 04:10 PM
  4. Holden Says Tune Your Car Ever 40k.you Hard Earnes Money Means A Lot To Holden
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-10-2005, 07:03 PM
