Results 1 to 6 of 6
Thread: can some one tell me where the clutch damper/spacer goes on a manual vn ???
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    Default can some one tell me where the clutch damper/spacer goes on a manual vn ???
    hey guys and girls,
    can some one tell me where the clutch damper/spacer goes on a manual vn i have put mine on the snout of the pedal cluster it seems right(its a vn v8 and t5 manual into a vl)
    though it's still not giving enough clutch pedal i just want to confirm where the sucker goes?? cheers
    this is a picture of how i have mine(don't mind the bolts i just tried spacing her out more lol can some one tell me where the clutch damper/spacer goes on a manual vn ???-001.jpg
    i may have some welding to do we cut out some of my fire wall to fit the vk cluster,though they have the long snout and vn are flat faced at the rear(maybe i should of cut the snout off and just used the grommet?)
    any one with an idea feel free to help lol
    My VL Walkinshaw replica project
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Why did you have to cut the panel? Im pretty sure mine already had a hole for the cable to go thru (was v8 auto before) I think I threaded mine thru a 14 or 16mm flat washer and stuck the adjuster at the firewall end
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    Jan 2008
    Actually, looking that im missing something on mine! Never knew there was meant to be a rubber bit in there
    Jul 2010
    sydney
    hey mate its actually been put into a vl(still is the same though i would say the pedal cluster is different that's why i'm having problems).
    so did you have a separate hole for the cable? not ran through the cluster snout?
    Quote Originally Posted by Andrew426 View Post
    Jul 2010
    sydney
    any chance you could grab me a couple of pictures of yours when you can?
    Jan 2008
    yeah il go outside and have a look, its getting a bit dark for photos now tho (ten to 8)
  1. Fuel Damper?
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2012, 01:09 PM
  2. [ACT] vr manual (needs clutch)
    By Braydenreid in forum Vehicles For Sale
    Last Post: 25-01-2011, 12:07 AM
  3. VX Strut top (damper top support)
    By MrSirWantalot in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-07-2010, 09:51 PM
  4. fuel damper adjustment
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-04-2007, 09:52 PM
  5. EFI 202 front fuel damper...
    By KBone in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-10-2005, 10:45 PM
