Results 1 to 6 of 6
Thread: Vn engine swap?
    matty94's Avatar
    matty94 is online now Addicted 2 VN's
    Vn Berlina
    Apr 2011
    Dandenong area S.E VIC
    Default Vn engine swap?
    Wondering if anyone can tell me if i put a ecotec out off a vx into my vn, would i need it engineered in vic?
    Yes i know theres a thread on this but i have got no answers in it.
    VN White Berlina Sedan V6 (S1) Full Lukey Exhaust Lovells Springs 15x7 Interceptors v8 Throttle Body Custom Tune Calais Grill Mulberry Calais Seats 2 12Inch Alpine S-Type Subs Level 3 Cluster.
    vn executive series 1 v6 1989
    Sep 2011
    maryborough
    im not sure it would be a lot of stuffing around with wiring and stuff but if you didnt have to change mounting spots or cut ur fire wall i wouldnt think so... not sure if thats right tho its just my 2 cents worth
    few commodores
    Feb 2011
    victoria
    http://vicroads.vic.gov.au/NR/rdonly...340/0/VSI8.pdf
    from what i've read in section 11, No engineers report needed, same number of cylinders, it's of similar size, similar power output and you shouldn't need to fabricate any mounts, basically a bolt in swap.
    quote "An engine which is not of the same type as offered by the manufacturer of the vehicle as original, but is similar in power, weight and emission standards to that of the original engine, may be fitted to such a vehicle, If alteration to the vehicle's frame or structure is involved and specially fabricated supports or structures are used, an Approval Certificate must be supplied"
    tbh i'd reckon be it a buick 3800 or ecotec it'd have to be classed as the same type of engine right? gm v6
    matty94's Avatar
    Vn Berlina
    Apr 2011
    Yeah that's what i thought because its basically the same engine and its a strait bolt in.
    Thanks for the info.
    Sep 2011
    maryborough
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    Im looking at doing a similar conversion but with an L67,
    There are 2 ways iv found that you can do it,
    1st - Is use the VN loom an ecu but you will need to get the eco tune burnt onto the VN memcal and extend a few wires.
    2nd - Is use the eco loom an ecu, but you will need to get the memcal modified (VATS off) - This is the way im doing as i got a memcal of this dude on ebay (NEW Holden VS VT VX VY V6 V8 VATS Security OFF | eBay) He is very helpful
  1. vx coughing and spluttering after v6 engine swap with wrong engine
    By bogan_vk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2011, 08:11 PM
  2. VT V6 ENGINE Swap
    By airia in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2011, 11:08 PM
  3. vr engine swap
    By buster1192 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2009, 08:32 PM
  4. Possible Engine swap
    By DUK13Y in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-12-2007, 11:19 PM
  5. Engine Swap
    By Dezza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2006, 07:16 AM
