Results 1 to 9 of 9
Thread: stop lights not working???
    vn v6 commonwhore
    Nov 2008
    Default stop lights not working???
    Hi crew, well my stop lights have ceased to go? All lights work but them, I have checked fuses & the switch on the brake pedal & they all good. Not sure what to check for next? any help please. cheers
    "If you don't like the way I drive, Then stay off the sidewalk"
    Ve r8 , VL turbo
    Oct 2011
    Camden
    Bulbs ,if you have a multimeter see if it's getting power down the back if not then youve got a broken connection somewhere
    vn v6 commonwhore
    Nov 2008
    The brake pedal switch works but there is no power from the two wires that plug into it? I don't have a multimeter just one of those little prong things with a bulb in it lol.
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    Is there any corrosion on the contacts?
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
    Vp S IRS 6 Banger
    Jul 2009
    Quote Originally Posted by Tim Smtih View Post
    Sounds like thats the problem too me, Pull the globes out and have alook.
    vn v6 commonwhore
    Nov 2008
    Cheers guy's, just had a look & there are a couple that are corroded so I will have a go at cleaning them up in next couple of days. Thanx
    Tim Smtih's Avatar
    Sep 2009
    Here.
    I had to get mine fixed for roadworthy when i sold it, mine were that badly rusted i tried to get a set from the local wreckers but it seems to be a fairly common problem. My mechanic ending up fixing it, i think he mentioned something about sandblasting and soldering if that helps.
    Albert Einstein
    Vp S IRS 6 Banger
    Jul 2009
    Go to your local pull a part and find good looms or cut off the globe holders and solder them back on
    xCalliba's Avatar
    xCalliba is offline EPICVN
    VT 9C1 5.0L & VN 'S' Pack project
    Mar 2008
    Kyabram, VIC
    had a similar problem, only it was intermittent, work sometimes then wouldnt the next. I ended up buying a new wiring harness for the rear lights, as soon as i replaced that, been gold ever since!
  1. stop lamp not working properly??
    By sickboy in forum Electrical Wiring / Questions
    Last Post: 20-06-2010, 02:14 PM
  2. vx power window stop working
    By MR_VX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-12-2009, 07:21 PM
  3. vn Calais rear lights, rear indicator, reverse lights and fuel gauge stop working
    By rustyguy085 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2009, 08:25 PM
  4. All Interior Lights stop Working When Headlights turned on
    By GMTANK in forum Electrical Wiring / Questions
    Last Post: 30-08-2007, 11:24 AM
  5. Km and trip stop working-Please help
    By KRATZ76 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2005, 10:58 AM
