Results 1 to 13 of 13
Thread: fuel smell in vr ute cab
    VR V6 manual ute, HSV VR GTS Series II
    Jun 2010
    Joondalup Area
    Default fuel smell in vr ute cab
    Hi, ok so not too long ago i got a VR manual V6 ute...
    Its got this hell bad fuel smell in cab. Notice it heaps more when i just put fuel in, but i think it always smells just heaps more when just been servo... help pls?!!?
    also... the holes behind seats arent blocked off and have no speakers in em but there is noway thats causin it, cos its pretty bad!! thanks guys, roxxy
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    Charcoal Canister flushing and inspection HOW TO
    Check all fuel lines for splits or cracks, check in and around fuel filter and fuel tank. The fuel tank can get hairline cracks in the top around the hose connection creating the smell when full. Check the link above
    Jun 2010
    Joondalup Area
    few commodores
    Feb 2011
    victoria
    replied to your other thread....
    remove the front floor panel in the back ute, the fuel tank is under there, check all the vent hoses on the top of the tank, if they're perished/come off the fumes will make it back into the cabin
    Rusty's Avatar
    Mar 2010
    Queensland
    I forgot to mention around the fuel filler neck as well. Remove the rubber around the fuel filler neck and check. Bring a mate when you fill up at the servo and get him/her to watch for leaks in the fuel tank under the access panel thingo in the tray.
    Another thing to check is around the fuel injectors also. Think that's it, good luck!
    few commodores
    Feb 2011
    victoria
    Quote Originally Posted by 94VRGTS View Post
    thats been siliconed down for sub.. but before that it was all checked and no evident signs of bad hoses etc
    that's going to make it difficult to check it out then
    Jun 2010
    Joondalup Area
    its been siliconed down for sub compartment... will b difficult yes, but it was checked before it was siliconed down... :/
    vr v8 ute
    Dec 2011
    qld
    Jun 2010
    Joondalup Area
    very bad i kno but havent got round to fixing it yet..! but i think i kno the prob, app the breather line is fkd, so thats where the REALLY bad smell iscomin from - its gettin worse... :/ ys that?
    vr v8 ute
    Dec 2011
    qld
    i have the same prob.but i cant work out which hose goes where.but i found a 6mm hose floating around under the tank,looks like i gotta pull the whole tank out to fix it....thinkin bout throwin a match in mine..
    VS SS 5L
    Oct 2008
    Had this problem on my VS SS, fixed it with metal putty stuff. it was cracks on top of the tank around where the metal hose fittings come out. When i bought my VG ute the fuel stink in the cab made me not wanna drive it, pulled the lid off(above the fuel tank), replaced one hose that was cracked and then found the same little cracks around the top of the tank where the hoses came out, got out the metal putty again and cleaned it, puttied all around it...problem completely gone. Its easy in a ute coz u come at the problem from above, dont even have to take the tank out. Coz like 20 bucks for the putty from any car shop and the hose i replaced was like 50cents.
    vr v8 ute
    Dec 2011
    qld
    VP executive sedan V6
    Feb 2011
    nowra, NSW
    sounds like the most likely causes have been flagged above but my daughter's VP had a faulty fuel return valve at the end of the fuel rail and that caused a petrol smell in the cabin and under the hood. Increased fuel consumption too
    cheers
    Rob
  1. VL with fuel smell / exhaust smell inside the car
    By jeffr001 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-10-2011, 10:31 PM
  2. Fuel Smell
    By mrhotdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2008, 11:51 PM
  3. Bad fuel economy, strong fuel smell?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 08:43 PM
  4. Fuel Smell
    By redvl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-08-2005, 09:42 PM
  5. VR Fuel Smell
    By ozute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-07-2005, 06:38 PM
