Results 1 to 9 of 9
Thread: rough idel/surging/missing
    vn executive series 1 v6 1989
    Sep 2011
    maryborough
    Default rough idel/surging/missing
    put fuel in my vn today and started it up was running fine but then it started surging an missing on 2 cyl i think soulded like it i also have a faulty tps could this be some of the problem for the surging and is there any way i can tell what cylenders its missing on or just replace all the plugs and leads? i also put a series 2 coilpack on not long ago but when i first put it on it made it run better so im not sure
    vn calais 5.0
    Jun 2011
    victoria
    When my tps died it would not idle at the lights and had to keep your foot on the gas as well at the lights to keep her running..Did it happen all of a sudden or slowly go like that? how long since the fuel filter change?
    Sep 2011
    maryborough
    Quote Originally Posted by mr calais 5.0 View Post
    fuel filter change a few months ago but its never really had that much fuel in the tank so it could have picked ip all the gunky crap off the bottom and im not sure if i slowly went like it it ran out of fuel and then i put fuel in it and noticed it was missing.. out of the exhaust it kinda sounds like a lumpy cam.. and i dont know what the problem is with the tps it idles but the engine light is on and i did the code and its 22 tps
    Sep 2011
    maryborough
    xCalliba's Avatar
    xCalliba is offline EPICVN
    VT 9C1 5.0L & VN 'S' Pack project
    Mar 2008
    Kyabram, VIC
    checked the injectors to make sure they are all clean mate? if you keep the fuel reasonably low then it may have picked up some crap?
    Wouldnt hurt to check them out, maybe give the fuel rail a clean out while your on the go
    few commodores
    Feb 2011
    victoria
    try fuel from another servo if it just happened when you did that, brand name or a new servo you haven't been to before?
    Sep 2011
    maryborough
    Quote Originally Posted by xCalliba View Post
    i was thinking about doing that and redoing the o ring seals because some of my injectors woble around might also change my fuel filter when i get around 2 it
    few commodores
    Feb 2011
    victoria
    the injectors will wobble and move around, unless you can see fuel stains which will be quite obvious, they're not leaking
    Sep 2011
    maryborough
    ok thanks for that and also i dont think my car is really missing (it might be) but my exhaust has a dirty hole in the muffler and when my car idels it kinda sounds like its missing but at the same time the exhaust sorta pops were the hole is so i was kinda thinking that its causing the problem (gunna get a lukey soon) also it dusnt do it in any real sort of pattern like it would if it was missing
  1. Rough Idle And Surging and ABS Light.
    By Deneo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2010, 05:37 PM
  2. Rough idle, GenIII, Surging through revs..
    By amadvk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2009, 06:54 PM
  3. rough idle/surging
    By VN FreNZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2009, 04:50 PM
  4. Surging/missing?????
    By hrforever in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-02-2006, 09:24 PM
  5. Need Help ! rough idle, stalling, surging
    By steve_o_85 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-02-2006, 09:17 PM
