Results 1 to 11 of 11
Thread: Airbox inlet nozzle doesn't fit through hole in metalwork
    VP Executive 5L
    Mar 2011
    Default Airbox inlet nozzle doesn't fit through hole in metalwork
    When I got my 304 VP it never had that piece that goes into the front of the airbox and draws cold air from above the front bumper, sort of. Just had a big rectangular hole, and when you gave it a bit of stick, once it got above 3000 rpm it sounded like a real hotrod from all the induction noise :-) Anyway, today I picked one up from the wreckers for the princely sum of three dollars and what a difference. At speeds below 3000 rpm there used to be a low level gritty growl proportional to how much you put your foot down that spoiled the smoothness of the car - now it is greatly reduced. But so is the > 3000 rpm sound - rats!
    There is one minor problem though - the open end of the plastic nozzle that pokes between the radiator bracket and the other side of the opening seems to be about 6-7mm too wide and so the inlet is partially blocked,maybe 20% or so. Maybe i should post a photo but it's dark right now. The nozzle was off a 3.8 but I think there all the same. Is it actually supposed to poke all the way through?
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Ok I can't picture what ur describing
    Try and get a pik in the morning?
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VP Executive 5L
    Mar 2011
    Righto.
    Car is parked right next to neighbour's car and a flash pic in the dark might have them coming out to see what's happening.
    VP Executive 5L
    Mar 2011
    VP Executive 5L
    Mar 2011
    This pic shows one of the brackets at the side of the radiator. See how it is angled outwards? Are they supposed to be like that or has someone jammed in a radiator that is too wide?
    Attached Thumbnails Attached Thumbnails Airbox inlet nozzle doesn't fit through hole in metalwork-airbox-nozzle-001.jpg
    vn calais 5.0
    Jun 2011
    victoria
    vn calais 5.0
    Jun 2011
    victoria
    VP Executive 5L
    Mar 2011
    That one is all round and curvy, mine is square like a lunch box. Hmmm...
    vn calais 5.0
    Jun 2011
    victoria
    VP Executive 5L
    Mar 2011
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    V6 and V8 airboxes are exactly the same. The only difference is that SV one you saw which from memory actually has a hole in the middle to go in the guard. Easiest solution rip out that snorkel cut the hole bigger problem solved.
  1. Hole in standard airbox.
    By Vy S SC in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-11-2010, 06:10 AM
  2. [VIC] VY SS intake set up w/ Monaro two hole airbox and GTS maf pipe, various items...
    By Cobez in forum Parts And Other Items For Sale
    Last Post: 29-09-2010, 02:04 PM
  3. MCAI and 2 hole mod on VT airbox
    By avanti_rider in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-04-2010, 07:06 PM
  4. [VIC] FS: VE SS Airbox+pipe+ Genuine Holden filter- 4" inlet
    By calaiscruzer in forum Parts And Other Items For Sale
    Last Post: 27-10-2009, 07:42 PM
  5. airbox/two hole mod
    By pac3y in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-01-2009, 09:38 PM
