Results 1 to 11 of 11
Thread: nolathane
    vr commodore executitve, manual vn executive
    Mar 2011
    sydney
    Default nolathane
    hey guys recently bought a vn 5spd, and its got nolathane bushes etc just wondering if there is anything better because the ride is very hard haha
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    Quote Originally Posted by brend94vr View Post
    mate i've just rebuilt a vl with most parts under it vn using nolathane bushes,
    my ride is superb,when where the shocks and springs done?(you probably have cheap crap or worn out crap)unless your ridding on 20s and cut springs lol
    that may be your problem!,from my knowledge nolathane is one of the dearer brands.
    My VL Walkinshaw replica project
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    using nolathane or urathane (sp?) it will give you a firmer ride. as uwishn posted, check your shocks and springs.. also what size rims and tyres you running?
    the only thing softer than the bushes you have are the original rubber ones. much much softer
    Mar 2011
    sydney
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Mar 2011
    sydney
    89 VN Exectutive
    Jan 2011
    The king springs would be your main problem if you are after a softer ride. Simple: get softer springs, a lot easier then replacing the bushes. (unless the bushes are stuffed then I would replace them anyway)
    vn calais 5.0
    Jun 2011
    victoria
    I never use nolathane just because it makes the ride harsher and they squeek and groan too.. MY last car was a Pajero wagon with body lift and running 33 inch muddies and it squeeked and groaned so much it s**t me up the wall..
    89 VN Exectutive
    Jan 2011
    Quote Originally Posted by mr calais 5.0:2050662
    Because nolathane is no good for a 4wd because when off roading you want everyhing to stretch to the limit. Which nolathane does not. Plain old rubber bushes are best for that.
    vn calais 5.0
    Jun 2011
    victoria
    When I got the paj it had most of them changed to nolathane by the previous owner. It was a family shopping wagon but I made it a 4by
    Rubber all the way mate..
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    I've replaced nolathane with rubber in my standard VN (factory FE2 with 15in tyres) and there is hardly, if any difference in ride firmness and tyre noise.
    A hard ride can be caused by a few things:
    *Low profile tyres (or harsh tyres such as Kellys)
    *Springs (as mentioned above) if it's low to extent where it's riding on the bump stops
    *Worn shockers -bottoms out easy
  1. Nolathane kit for VX
    By SlvrR8 in forum General
    Last Post: 25-10-2011, 09:23 PM
  2. Nolathane vs Rubber
    By madsav in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-11-2010, 03:25 PM
  3. Standard or Nolathane?
    By 9C1pack in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-09-2010, 11:03 AM
  4. nolathane bush kit
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2007, 08:21 PM
  5. nolathane bushes
    By ghostVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2004, 10:39 PM
