Results 1 to 1 of 1
Thread: Speed Issue's
    VH stock
    Nov 2011
    Dennington
    Default VN conversion wont go over 40km/h???
    I've just completed a VN 5speed conversion into another car (not a commy) . . The car "Cuts out" at 35/ 40km/h, the motor die's but then will come alive again until a similar speed, so it's kangaroo hopping down the road. Doesn't appear to matter which gear it seems to be in. I've replaced the speed sensor, 2 different memcals (Standard and Mod) but i don't have a speedo plugged in. I have a highly mod speedway memcal which has a lot of the reading stripped off it, which has the car driving like it should through the gears but rough idle and hesitation is quite bad but i want to have the car runnng on the stock chip so the problem then is fixed . . It has a VP series2 engine loom which has the 2 wire Oxy sensor and the computer is VN "series 1" . . is this a problem . . .
    Thanks
  1. 97 vs ss manual issue's
    By jonnyturbo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2011, 09:29 AM
  2. VY ABS issue's
    By TrEnNaVY in forum General
    Last Post: 03-05-2010, 08:01 PM
  3. Issue's after lowering
    By -=ApheX=- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2009, 02:24 PM
  4. Speed Issue's
    By Darren in forum Site Feedback / Site Problems
    Last Post: 17-06-2006, 12:42 PM
  5. HELP ECU ISSUE's
    By roger05 in forum V6 Development And Modification
    Last Post: 21-01-2006, 06:30 PM
