Hey guys just wanting to find out if there is a difference between a T5 V6 & V8 tail shaft?
Only the front slip joint, the shaft itself is the same
Sent from my ATRIX using Tapatalk
So is it possible for me to use a V8 shaft for my V6 conversion to VK using thew front half of the V8 shaft to the back of my vk to diff.
you only need to change the front yolk over, not the half shaft
