Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By VT-565
Thread: Snapped bolt.help!
    VX Berlina Wagon
    Oct 2007
    Default Snapped bolt.help!
    Gday guys, I was tightening uP the nut that holds the bottom of the shock. And it snapped off with the thread. How do I put a new thread? Or how do I fix it?
    69 rs ss camaro/ rodeo dual cab
    Jul 2011
    adelaide
    Default oops
    Youll need to helicoil it, theres guys who come out and fix e like doctor thread etc look in yellow pages. Good luck
    Vk ls1 turbo
    Aug 2009
    townsville
    or tap it out to one size bigger. did any of the thread snap off in there you might need some easy outs to get it out if it did
    2002 HSV GTO COUPE
    VK calais ls1 turbo conversion (in the build)
    2009 turbo v8 landcruiser
    My VK http://forums.justcommodores.com.au/...-vk-355-a.html
    VT
    Apr 2005
    QLD
    take the shock back off, if you're lucky, there may be a piece of bolt protruding. Grab these as tight as you can with vice grips and try and remove it.
    VX Berlina Wagon
    Oct 2007
    The bolt that the shock slides over it actually apart of the diff. So the shock still sits in place, just the thread on the end has been snapped off.
    VT
    Apr 2005
    QLD
    So its not actually a bolt.
    Best bet would be to get a set of easy outs, drill the bolt and remove it.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Quote Originally Posted by VT-565 View Post
    What he said, use easy outs, failing that weld a nut to the top of it and undo it that way
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    few commodores
    Feb 2011
    victoria
    Quote Originally Posted by King_berald View Post
    the bottom of the shock should sit between 2 plates of metal with a nut and bolt going through those and the shock to hold it in place, inline with the lower control arm..... should slide out pretty easily and not be attached to the rear axle, only thing i can think of matching your description is the panhard rod mount
    vn
    Nov 2009
    noble park
    Its a wagon I thinks old mates activar gives it away. How tight did you go to break that? weld a piece of a bolt on to it.
    few commodores
    Feb 2011
    victoria
    i'll blame the gregorys manual then, thought wagons were different but when i checked the book the only mention of any change was the top shock mount for a wagon
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    All VX's wagon or sedan or ute have a pin that the shock bush slides over, then a bolt screws into that with a washer to hold the shock in place.
    Drill a hole in the end of the snapped off bit and use an easy out.
    Visit my Facebook page
  1. Bolt snapped in engine.... services?
    By VLSabo in forum General
    Last Post: 18-01-2011, 04:41 PM
  2. Snapped Clutch Bolt
    By HÝPÕ-5L in forum General Discussion
    Last Post: 12-11-2010, 08:34 PM
  3. Snapped manifold bolt
    By stocky in forum General
    Last Post: 01-08-2009, 08:41 AM
  4. Bolt Snapped
    By tr3nt in forum General
    Last Post: 07-12-2008, 11:58 AM
  5. Snapped bolt... HELP!
    By MBS206 in forum V6 Development And Modification
    Last Post: 13-06-2006, 10:06 PM
