Results 1 to 6 of 6
Thread: Vp cluster in vn how do u remove cluster pins
    Excale's Avatar
    Excale is offline Aussie N Proud!
    VL Berlina 5sp Manual[SOLD], VN V6[SOLD],VR S 5sp
    Mar 2009
    Melbourne, Aus
    Default Vp cluster in vn how do u remove cluster pins
    Just put a vp cluster with a tacho into a VN berlina, everything seems to be working except for the right indicator light on the cluster does not show but it is working, it's not globes its apparently pin 10 is ment to be in 11 on the cluster loom... How do you get the pins out to move them?
    Excale's Avatar
    Mar 2009
    Melbourne, Aus
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    You need to take the yellow locking tag out first and then press down at 90 deg to the wire from the top with a pointy scribe or similar. This allows the conector lug to come out of the plug.
    Just in case - you will need to "pop" the plug forward out of the dash to get to the yellow locking tag. The tag keeps the wires in place and stops the lug taking all the pressure if some one tugs on the loom too hard.
    and 3 Dangerous non ABS VN's
    88GreenVN's Avatar
    Jun 2006
    Dont forget to move the 2 brown white wires over 1 slot also on connector 1 - this is the engine warning light and the other is brake warning I think.
    Excale's Avatar
    Mar 2009
    Melbourne, Aus
    Okay i managed to move around some of the wires on the cluster loom but for some reason my right indicator doesn't show up on the cluster but it's actually blinking outside the car...also when i pull my handbrake up, the right indicator picture comes on solid but doesnt flash as if its meant to be the park light, but my left indicator works fine.
    Cheers for all your help.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Excale View Post
    If you have both clusters handy look at the numbers printed on the back of each and note the 3 or 4 differences. You will need to match the the VN pinout.
    Other option is to fit the gauge set from the VP into your VN cluster. takes a little while but you poke the 7 holes needed and scratch off the green or blue coating and it will work fine. I've converted probably 30 clusters like this and never had an issue.
  1. How do i remove the cluster facia ?
    By HSV5L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2011, 08:37 PM
  2. How to remove instrument cluster
    By RedHot in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-04-2010, 09:58 PM
  3. How to Remove Entire Cluster in a VT
    By nabed4t in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2008, 06:00 PM
  4. How to remove needles from VX instrument cluster???
    By 5N!P3R in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-09-2005, 05:03 AM
  5. Replies: 1
    Last Post: 11-09-2005, 10:00 AM
