Results 1 to 6 of 6
Thread: Engine swap help, VG V6
    '91 VG Ute
    Nov 2011
    Tamworth
    Default Engine swap help, VG V6
    Hey guys, on the weekend I put a replacement engine in my 91 vg ute, Ive gone from a series 2 to a series 1 and i'm having a few cooling issues, the plumbing on my old engine was a fair bit of a mess with heater hoses blocked off all over the place, and with a different system on the s1 engine I'm a bit lost. I also only have the s2 overflow bottle, and Im not exactly sure that I have it plumbed correctly (if theres one thing I can never get my head around it's cooling systems) I am just about to put a new thermostat in and hope that it fixes the problem, but I'm still concerned about heater hoses and whatnot being in the wrong place, so any help would be greatly appreciated ie: where all the hoses go to and from.. thanks in advance
    Do it once, Do it right!
    matty94's Avatar
    matty94 is offline Addicted 2 VN's
    Vn Berlina
    Apr 2011
    Dandenong area S.E VIC
    Unless you run the early (S1) water bottles and radiator your always going to have cooling problems.
    VN White Berlina Sedan V6 (S1) Full Lukey Exhaust Lovells Springs 15x7 Interceptors v8 Throttle Body Custom Tune Calais Grill Mulberry Calais Seats 2 12Inch Alpine S-Type Subs Level 3 Cluster.
    vn calais 5.0
    Jun 2011
    victoria
    best bet would be to get a gregory's manual or the equivlant and have a look at the pics of it all or get someone to post pics of how they go..
    '91 VG Ute
    Nov 2011
    Tamworth
    '91 VG Ute
    Nov 2011
    Tamworth
    The decision has been made to buy a series 1 vn.. found one running, cheap as chips, so it will be a parts donor. Failing that I'm left with head gaskets or cracked head as far as I can tell? any other suggestions???
    s1 vt
    Jul 2005
    swap all the top end manifold and stuff off the s2 motor onto the s1 and bolt back in.
  1. vx coughing and spluttering after v6 engine swap with wrong engine
    By bogan_vk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2011, 08:11 PM
  2. 5l engine swap help.
    By Clint_G in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2010, 08:48 PM
  3. Vh engine swap?
    By hellsvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-11-2010, 03:17 PM
  4. vn-vt engine swap
    By jessiepal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2007, 07:59 AM
  5. v6 engine swap
    By charged vp in forum V6 Development And Modification
    Last Post: 06-08-2006, 08:53 PM
