Results 1 to 4 of 4
Thread: Vp v6 rough idle and stalling!
    vy ute, vp sedan
    Jan 2011
    geelong,vic
    Default Vp v6 rough idle and stalling!
    hi everyone, my 92 vp executive has had a problem with idle for a while now. it will run fine for a bit after starting but then it will start to chugg and puff black smoke and eventually stall if i dont keep the revs up, also the engine light starts flickering while driving, tried getting fault codes but engine light just continues to flicker. heres a list of things i have tested, cleaned or replaced. iac valve cleaned, throttle body cleaned, crank sensor replaced, coolant temp sensor replaced, new plugs, leads, coil pack and dfi replaced. i am leaning towards ECU or oxy sensor. please help!!!
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    id try an oxygen sensor, and work out why your check engine light is not working properly.
    vy ute, vp sedan
    Jan 2011
    geelong,vic
    got a new ecu today, il try it tonight and post how it goes, bought a sv3800 tune as well...just for kicks
    vy ute, vp sedan
    Jan 2011
    geelong,vic
    new ecu....problem solved!!
  1. VR Auto - Stalling, rough idle, CEL
    By M4SH3R in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2011, 06:32 PM
  2. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  3. stalling backfires whooshing sound rough idle
    By vn reaper reborn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2010, 01:52 AM
  4. Vt stalling / running rough HELP PLEASE!!!
    By icewhitevt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-08-2009, 07:51 AM
  5. Need Help ! rough idle, stalling, surging
    By steve_o_85 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-02-2006, 09:17 PM
