+ Reply to Thread
Results 1 to 6 of 6
Thread: sneaky little switch
    VN S pack
    Aug 2005
    Default sneaky little switch
    i've just been doing the error test on my comp and found two disconnected wires that run to an on off switch that was actually mounted under the centre bit behind the handbrake.
    at some point in time it was hooked up on the pink wire going into the comp.
    what wound this have done? should i hook it up or will it do bad things to my car?
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    Geez, can you tell me what coloured wires of the ECU connection this switch was switching. I will get out my gregory's manual and see what the pink does. Maybe someone was fiddling with trying to bypass a sensor or something to get more rich fuel mixture or something.
    Yours Kindly,
    Jim
    VN S pack
    Aug 2005
    it only connected to the pink wire, basically an inline switch. all i can think is the person who owned it before me used it as a cheap immobiliser or something. i could be completly wrong. would love to know.
    Feb 2004
    NSW, Australia
    vinnywelsh's Avatar
    vinnywelsh is offline Bored Technician vinnywelsh Calais
    VN V6 3.8L Berlina
    Aug 2004
    Id have to agree, its most likely a home made immobiliser. especialy if it was hidden along the side of the handbrake.
    VN S1
    Sep 2005
    It's not a way of bypassing the torque lockup is it?
+ Reply to Thread
  1. air con switch? VS
    By ianf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2007, 04:23 PM
  2. Engine Cooling Fan Override Switch - Using an A/C Switch
    By Maiku in forum Holden Commodore How-To's
    Last Post: 14-03-2007, 10:59 PM
  3. Removing aircon controls, mode switch, light switch
    By wrx884 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 10:53 AM
  4. switch for WOT
    By chevy_big_block_bro in forum Electrical Wiring / Questions
    Last Post: 01-12-2005, 08:29 PM
