Results 1 to 7 of 7
Thread: [Help please] Can't enter diagnostic mode
    89 VN Berlina 5sp 3.8
    Apr 2010
    Default [Help please] Can't enter diagnostic mode
    Hello I've got a vn v6 and i've checked for errors many times no probs by bridging the white and black wire with a paperclip, I've just recently put a new clutch in and o2 sensor out of another car because mine was buggered. I also changed memcal to a different 1 and decided i didnt want it anymore so changed it back to original factory 1.... disconnected the negative terminal for 10 mins and reconnected and went for a drive to find the engine light coming on again.. so suspecting its the o2 sensor again i went to bridge how i normally do but now nothing at all is happening... turn the ignition to on and all the usual lights come on as normal but wont enter diagnostic mode. Tried like 5 paper clips and different bits of wire and its definitely not working now. Perhaps the ecu is buggered? is it even possible to maybe put a memcal in backwards? im guessing it isnt and the car probably wouldnt run if it was... any suggestions guys? cheers
    Apr 2010
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    doses the engine light come on when you turn the key into the reds (accessories)? if it dosent the globe is blown and the car wont self diagnosis if this circuit is broken.
    dont sweat the petty... pet the sweaty...
    Apr 2010
    Quote Originally Posted by hi_ryder View Post
    Yeah it comes on as normal along with all the other lights, just for some reason it does nothing now when i put a paper clip into it. tried many times. Would changing the ecu itself help?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You're obviously putting the paper clip in the correct terminals of the plug? Is the connector pushed hard all the way into the ECU?
    Visit my Facebook page
    Apr 2010
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Yeah definitely, i mean ive done this so many times i could almost do it with my eyes closed, i unplugged them and put them back in and made sure they clicked in hard but still no go. I wonder if changing the ecu will solve this problem?
    few commodores
    Feb 2011
    victoria
    try another ecu. or use a long piece of wire and connect the diag mode pin to a good ground on the body of the car and see if that makes a difference
  1. vt police/diagnostic mode
    By nick.888 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2011, 09:16 AM
  2. When does the car enter closed loop mode
    By aceventura in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2009, 08:23 AM
  3. VZ SS Diagnostic Mode
    By Blown VS in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-01-2007, 06:08 PM
  4. How to put VN 5.0L in diagnostic mode
    By vq~gangsta in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2005, 09:21 PM
Tags for this Thread
