Hi,
I was looking through the my ride vn-vp section and i noticed on some cars the headlights are dead straight in line with the car and on others they are wonky or not even with each other.
Im having a similar problem with my vn in that the drivers side headlight doesnt line up with the right hand side one at all, there doesnt seem to be anyway to adjust the way it sits either, the headlight in question is a TYCO reproduction and not a GM one so im wondering if thats the culprit or if it can be adjusted in some way,
Any help is much appreciated
pics?.........
dont sweat the petty... pet the sweaty...
almost looks like you bonnet could use an adjustment... driver side where it meets the guard and indicator. maybe the bonnet could come froward a touch. as for the lights being out of wack it could just that there after market POS or even that your rad support could be a little off from a prior shonky repair, or could be the bonnet is bent. got any panel beater mates? they could probably get it squared up within 20 or 30 mins. shouldnt be a hard fix though....
Thanks for the reply
Nah no panel beater mates unfortunately, I might try to get some Gm headlights and try them out then have a look at the bonnet adjustment, How do you adjust the bonnet?
