Results 1 to 5 of 5
Thread: speed sensor??? help
    vn executive series 1 v6 1989
    Sep 2011
    maryborough
    Default speed sensor??? help
    got a problem with my vn only thing it needs for a roady is to get the speedo working.. it worked when i got it. then i put a vp lvl2 cluster in, it worked still. then all of a sudden it stopped i thought it was the cluster so i put the stock 1 back in.. no good nothing, so i completely pulled apart the vp speedo looked all good so i put it back in still nothing so im thinking its the speed sensor i know were it is but do i just replace the black bit with the plug that screws on or the part behind that.. if so how do i get it out? i undid the 10mm bolt but thats as far as i got i couldnt get it out. is it srewed in or press fitted?
    VL Commodore
    Aug 2011
    Melbourne, VIC
    Sep 2011
    maryborough
    vn calais 5.0
    Jun 2011
    victoria
    Undo the bolt and the plug and just pull it out.. You will get a little bit of oil, not heaps and put the new in.. Mine worked and stopped and worked then sometimes worked then died.. There cheap part
    Sep 2011
    maryborough
    so it just pulles straight out thats all i needed to know but i dont get y my odometer works but the speed doesnt
  1. [NSW] WTB: VS V6 Speed Sensor - Woy Woy
    By JoshSvc in forum Swap / Wanted to Buy / Trade
    Last Post: 29-06-2011, 11:46 AM
  2. vr t5 speed sensor
    By giffo2010 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2011, 01:43 PM
  3. HSV R8 front left wheel speed sensor - replace just sensor? or need to the whole hub?
    By hsvmaster in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2011, 09:05 AM
  4. Replaced Cluster and Speed Sensor, still won't show speed - only in ALDL
    By VS Omega in forum Electrical Wiring / Questions
    Last Post: 24-04-2009, 06:39 PM
  5. HELP: No Speed sensor, what happens?
    By simc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2005, 10:51 AM
