Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Like Tree1Likes
Thread: legality of pvc cai
    shaggyvn is offline shaggyvn
    vn executive bt1
    Jan 2012
    murray bridge
    Default legality of pvc cai
    so i rang the mong at the v.i.c and he said i can cut a hole in the bottom of my airbox and the metal so long as its machine cut? and insulated so rubber on bare metal ive looked and cant find anyone thats done this this way and if i have photos wernt showing if anyone can help would be great
    my cars full of german shephard try and steal it buddy
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    No holes in metal work unless it's been certified by an engineer last I checked. Wouldn't even waste the time drilling holes in the metal. Cut the hole bigger where the snorkel goes and it will be more then enough.
    vn executive bt1
    Jan 2012
    murray bridge
    the fella at the vehicle inspection joint says as long as its machine ct and insulated its fine (im in sa)
    ducker85's Avatar
    ducker85 is offline Calais man
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    its so you can run a 3 inch plumber's pipe straight down and fit a POD to it, dont bother just buy a holden VS L67 CAI and your set plus it only cost like 80 bucks
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    He's doing it because that's what every one does because people think putting a pipe down the bottom is going to unleash the killawasps. Which it won't. Don't even waste your money on that heatsoak intake. Do also take into account if you have an accident and they see you have this lovely 3 inch hole cut through a piece of steel they will have a field day.
    VRCALAISS is offline Banned
    94 VR CALAIS 3.8L V6
    Jan 2011
    Morayfield,QLD
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    I did it on my VR. I guess it worked, I dont really know as I fitted a set of YT roller rockers at the same time.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    vn executive bt1
    Jan 2012
    murray bridge
    the way i see it its an a dunga vn theres no point spending large cash he cars not insured so insurance isnt a problem ill see how it goes and upload if people want and if anyone has photos of one already would be great
    vn executive bt1
    Jan 2012
    murray bridge
    noob question (heatsoak)?
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    If it's a dunga VN then just cut a bigger hole at the front of the airbox where the snorkel goes. Easiest and best solution. Heat soak meaning the super 6 cold air intake sits on top of a hot radiator which in turn makes the air it gets in hotter.
    D22 St-r Navara
    Dec 2010
    perth
    i wouldnt think the air has time to heat up as its passing the so called heatsoak at a nice pace
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by Krisp View Post
    It has been legitimately proven to be a heat soak. Can't be bothered to find the thread.
    D22 St-r Navara
    Dec 2010
    perth
    Well radiator will heat the plastic cover, but the air passing through the cover passes through too quick to heat up . Might heat up if you park the car infront of a wall in the sun to reduce the airflow
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Did yout not read what I just said. Some body did back to back on road tests of the super 6 cai and it was found to have big heatsoak issues.
  15. #15
    D22 St-r Navara
    Dec 2010
    perth
    i can have my own opinions on what i think is right, regardless of whoever else has a difference in opinions
  16. #16
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Your opinion has proven to be wrong. Accept the fact and move on.
  17. #17
    ducker85's Avatar
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    Quote Originally Posted by wraith View Post
    and thats why OTR are not even popular with the LS boys
    it was MACE who done the test it was like 2 degree's hotter then an enclosed pod. the cool air passes thru the bonnet/grill and into a possibly 'warm' plastic mouth into the air filter. you'll pay $80 for the 'heatsoak' intake and $60 for the pod plus the hassel of cutting the hole and getting pipe.
    If your gonna claim a test has been done be willing to post a link before being stubon and getting sh*tty with other members
  18. #18
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by ducker85 View Post
    /snip
    Your stupidity is going to get me infracted again. The OTR on an LS1 is aimed over and facing down usually. Mace had nothing to do with the test. If you can't get off your ass and search then why should I bother. Plenty of other users can verify my claims.
  19. #19
    vn executive bt1
    Jan 2012
    murray bridge
    i have plenty of pvc so cant hurt with the over the top ones i worked at d&t performance a lot of cai/ram intakes are on the radiator at idle they have been known too warm the air quite a bit on the eights on the 6s i wouldnt want it at idle they dont suck quite as much so its gonna get hot (imho)
  20. #20
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
  21. #21
    D22 St-r Navara
    Dec 2010
    perth
    Seems someones knickers are in a knot, thought about counseling before you go and label random people stupid?
  22. #22
    ducker85's Avatar
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    I read the the test when I was into the L67's 2 years ago and im sure it was MACE because they do an enclosed pod where FIT do a OTR style and a cheap hose under the bumper style CAI and there the only to brands I looked into.
    I had a quick look but couldn't find the test. There's still no need to get worked up, abuse other members and get another infraction.
    calm down, stress is bad
  23. #23
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    As I keep saying I don't suffer fools. Some one trying to prove a point which has been proven to be incorrect bugs me. I haven't even begun to abuse people. FYI I am calm
  24. #24
    Dec 2009
    Quote Originally Posted by shaggyvn View Post
    Does it really matter if it warms the air at idle and reduc es power, the car's not moving? Isn't most of the heat soak that heats the intake air into the intake manifold as it's sitting in the engine's V?
  25. #25
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    It does if your spending money for no gain when just cutting a bigger hole at the front is free and better.
  1. Legality of aftermarket lighting
    By jamiebrown in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2011, 01:07 PM
  2. legality of changing odo cluster....
    By TheForgotten in forum General
    Last Post: 21-07-2009, 07:41 PM
  3. Legality of Adjustable Rear Coilovers?
    By 1991_Vn2nV in forum General
    Last Post: 07-01-2008, 09:01 PM
  4. legality of 17s / how to
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2006, 12:34 AM
