Vn clubsport V8 5L knock sensor problem.
Diognostic test says knock sensor had a look and its blocked off with a bolt. There is a cut red and white wire comes out off left hand lower fire wall traced back to computer dd. Is this wire for knock sensor does any one know what it is. Checked computer and has after market chip i reserched the name on the chip and had no resuts. When you first start it it runs good after 60 seconds engine light comes on and runs ruff. The guy i brought it off said it has a lumpy cam and senator 215i crank It has blue top injectors and cai the car does not sound stock Any help apreciated thanks.![]()
The chip say's TVNAM152 anyone know what it means ? cheers Travis.
i will wonder down the back, i have a vp senator ecu , lets see what the code is on that
nope no idea
Thanks anyway its the chip that plugs into the computer i think its aftermarket cheers.
the red and the white wire on this vp senator loom is for the knock sensor
Thanks heaps mate is it just the one red and white wire.
yep, goes straight from the plug to the sensor plug
You are a legend mate thanks heaps![]()
your just lucky that the motor isnt fully in the car and the wiring is everywhere, no probs buddy
Thanks Krisp![]()
