evening guys, i bought a vn/vp v8 t5 gearbox, flywheel, used clutch and tailshaft yolk for $250, and got a question, what block pattern are they?? turbo or trimatic, i think i got it cheap, so im happy, it'll go into the shed until i build my next hq ute and go inj 304, it might go into my old mans wb yet, depending on what patten it is and what patten the 253 were looking at for it
cheers
V6Q
oh heres a few photos
yeah hopefully shes a good box, i havent looked deaply into it yet i only got it this arvo, if i find out what pattern they are it will be a start in the right direction
Sure you can use it but not sure the pattern it bolts behind. The newer blocks maintained one of the patterns. Also think the clutch spline is the same as the m20,m21 & 3 spd all sync box of the earlier model V8's
The bell-housing will be to suit turbo block. All holden V8 block from VN onwards where to suit turbo pattern.
Hot Lap Motorsport
cheers, the 253 im looking at is a trimatic, have to invertigate a adaptor or see how much itll cost to get the block redrilled
