Results 1 to 4 of 4
Thread: Oxygen Sensor Wiring Diag VP
    VP commodore in Hiace
    Jan 2012
    tweed heads
    Default Oxygen Sensor Wiring Diag VP
    Guys, I have a vp6 in a Hiace. Having an issue with wiring. Need to know if the earth on the O2 sensor goes straight to PIN6 without grounding to any earth circuit... OR if the earth on the O2 sensor grounds to the motor/chassis then continues to PIN6. This wiring issue is very important, because if it is not done correct the motor with run in Open Loop.
    PLSSSSSSSSSSSSSSS HElP. Does mechanic out there have the proper wiring diag. NOT the ones in the repair manuals, they are not specific enough.
    Jan 2012
    tweed heads
    Not to sure why the green smilely face. supposed to read pin-d6.
    Anyway, i went to the wreckers today and they let me have a look at a VP. really happy about that.
    I should note: that i ment to say the black ground wire on the O2 sensor; not "the earth on the O2 sensor". it is a little clearer.
    I tested the circuit and i can confirm the black ground wire on the O2 sensor goes to pin-D6 on the ECU only. it does not ground to the chassis or engine. Hopefully this may help someone else out, in the future.
    few commodores
    Feb 2011
    victoria
    it really doesn't matter where it grounds, as long as it's grounded
    a s1 vn uses the same ecu but only a single wire o2, it gets it's ground through the case to the exhaust, i've fitted a 2 wire o2 as a replacement and grounded it to the screw for the map sensor, it works fine and has done for the past year.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Personally i'd suggest that you earth the O2 sensor on the engine block as the engine block is the earth point for all the sensors (it's where the wiring loom earths go). I've done this on my VN (originally didn't have a O2 sensor at all and it works fine).
    edit: this site has good wiring diagrams http://www.google.co.nz/url?sa=t&rct...4p9yTbCV27RcJA
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. Oxygen sensor for 5.0L
    By mr j-man in forum V8 Development and Modification
    Last Post: 11-06-2011, 01:11 AM
  2. VR wiring Diag
    By iank in forum Electrical Wiring / Questions
    Last Post: 26-03-2007, 09:02 PM
  3. Oxygen Sensor wiring
    By DavoX7 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-05-2006, 10:06 PM
  4. No oxygen sensor
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-10-2005, 05:03 PM
  5. oxygen sensor? wiring fixed
    By symo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2004, 07:54 PM
