Results 1 to 7 of 7
Thread: Fuel Injectors 3.8 S2 VP Upgrade?
    TG Gemini 3.8
    Dec 2011
    Default Fuel Injectors 3.8 S2 VP Upgrade?
    Im having a little trouble with obtaining info on an injector upgrade for my VP V6. The old girl currently runs stock setup other than a crow stage 3 cam, high lifters, and larger throttle body. The engine is currently mated with a T5 Tranny and the whole shooting match has been dropped into a gemmy. The ECU is stock other than the Crow Cam upgrade chip.
    Does any have previous experience/info on going with larger injectors for a similar setup? Ive heard Magna injectors are a suitable upgrade??
    Will I need to have the ECU recalibrated for the larger inj.?
    Any info greatly appreciated ladies and gents.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    few commodores
    Feb 2011
    victoria
    Quote Originally Posted by wraith View Post
    You don't need larger injectors. The stock setup is fine.
    agreed, the std injectors are fine, you would have to reprogram the ecu to lower the flow of the larger injectors, no point really for an na v6.
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    If you have no idea when they were last replaced for piece of mind you can pick new ones up for dirt cheap on ebay and their perfectly fine.
    few commodores
    Feb 2011
    victoria
    even putting a kit through them can be fine aslong as they're not to old and worn, new filter, orings and tip
    HOLDEN V6 BOSCH FUEL INJECTOR REPAIR KIT V6 CYL | eBay
    TG Gemini 3.8
    Dec 2011
    vn calais 5.0
    Jun 2011
    victoria
    Didn't know you could get a rebuild kit for injectors, thought they were a throw away item
  1. vz sv6 should i upgrade my injectors
    By phillsau in forum Sticks's EFI parts
    Last Post: 06-03-2012, 05:36 PM
  2. VL fuel injectors
    By oxmate in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-09-2010, 12:44 AM
  3. [VIC] Fuel tank & reco fuel injectors
    By BT1-355 in forum Parts And Other Items For Sale
    Last Post: 25-11-2009, 03:36 PM
  4. Injectors Upgrade For 5 Litre 304 V8
    By RVN 355 in forum V8 Development and Modification
    Last Post: 12-05-2006, 07:23 PM
