Results 1 to 8 of 8
Thread: knocking noise in engine
    vr commodore executitve, manual vn executive
    Mar 2011
    sydney
    Question knocking noise in engine
    ok guys i was just took the car for a drive and at idle there is a knocking noise anyone know what the problem is???
    vn calais 5.0
    Jun 2011
    victoria
    Mar 2011
    sydney
    VR v6
    Jan 2011
    perth
    Check the harmonic balancer..or if its at the back it could be balance shaft bearing
    More info needed to diagnose
    Mar 2011
    sydney
    my mate who has the same noise reckons its somethn to do with the exhaust???
    VT S2 - SS intirior - Ls1 Project!
    May 2011
    Sunny coast
    i doubt that, sick your head around the engine when you can here it and listen... how often do you do service the motor?...
    VP executive sedan V6
    Feb 2011
    nowra, NSW
    try using a short length of garden hose as a kind of stethoscope (except you just point it towards the area you want to listen to rather than holding it against). It will isolate the noise source and give you a clue as to what it might be.
    If you've only got 1 rattle I'd say you're lucky
    Mar 2011
    sydney
    had a look at some youtube vids of commos with engine knocks and found the same as mine its the harmonic balancer and is getting done on wednesday, i have only owned it for a few months so i have only serviced it once. the dude who had it before me was a gronk on his green p's
  1. HELP, loud knocking noise in my engine.
    By aectk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-11-2010, 07:36 PM
  2. Knocking noise from engine maybe.
    By SSbeast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2009, 07:37 PM
  3. Knocking noise in engine at startup when cold
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2008, 05:56 AM
  4. VT 5.0L Engine Knocking Noise?
    By Spitfire in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-08-2006, 08:06 PM
  5. engine knocking noise
    By grigor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2006, 06:06 PM
