my vn series 1, 1989, keeps blowing its 15a fuse after its starts up. WHY ???
might do a self diagnosis see if theres any error codes coming up...
dont sweat the petty... pet the sweaty...
does the car run?
instantly blowing it or takes some time?
is the fuel pump making any noise?
if you unplug the fuel pump at the tank does it still blow the fuse?
sounds silly but have ya checked that that is the correct amp fuse for the fuel pump... it should be writen on the fuse cover
If in doubt......FLOOR IT!!!
mine did the same and turned out to be a burnt out fuel pump.
disconnect oil pressure sender and see if it blows if not replace oil sender
